Of grid plumbing
   / Of grid plumbing #11
I think you're simplest solution is going to be solar. A really simple system, where the pump is direct-coupled to the solar cell, no inverters or storage batteries. When the sun shines, the pump runs and fills a tank.
   / Of grid plumbing #12
On-demand pressurizing pumps work in RV's from a tank. Pump water from a cistern to a tank with solar and charge a pump battery maybe.
   / Of grid plumbing #13
Heck, just keep a deep cycle marine battery on a solar charger that powers the RV pump and you're good to go.
   / Of grid plumbing #14
An intermediate tank would be a good place to add some filters and sanitizer method (UV, whatever) if water is coming from run-off into a cistern.
   / Of grid plumbing #15
Sounds kind of like an RV that never moves. Just operate it like an RV with water stored and pumped via 12v.
   / Of grid plumbing #16
I'm not clear about the pressure balancing valve?? What does that do for you? Never heard of one.
If you put an insulated hot water tank on the tank tower with a check/ balancing valve in between them, and put a wood burning outdoor stove with a heat coil to the hot water tank, you will have the same pressure on both lines, and plenty of pressure for a shower/ sink/ toilet.... You just need to dig the well to periodically pump the water up to the tank....
2017 Freightliner M2 106 TMA Attenuator Truck (A52377)
2017 Freightliner...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
2008 Ford F-250 (A55218)
2008 Ford F-250...
