pto clutch seems locked up. how can I free it?
   / pto clutch seems locked up. how can I free it? #1
harleyman1903
Walterboro, SC
John Deere 1050
I have JD 1050. It is a 4 wheel drive with power steering and pto. The clutch doesn't seem to be disengaging properly any suggestions. Also looking for a ball joint for the steering arm to the the power steering unit. Any help would be appreciated.
   / pto clutch seems locked up. how can I free it? #2
Is clutch pedal free travel adjusted correctly? You could try operating a pto dyno(if local dealer has one) with clutch pedal blocked down.
   / pto clutch seems locked up. how can I free it? #3
Worked on a 1070 a few years back. It was a two stage clutch that was stuck to the flywheel. With the clutch pedal blocked down, I was able to pop the clutch plates free with a screwdriver through a access hole, I believe was on the right side of the tractor.
   / pto clutch seems locked up. how can I free it? #4
Hook up an implement (like a mower) and operate it with the clutch pedal depressed. It will soon disengage. I don't recommend prying it. This might fracture the organic clutch material or scratch the flywheel. That will lead to premature wear-out. Just run the machine for a few minutes with a load on it.
Appreciate your advise. I will give that a try. Not looking forward to splitting it right now.I'll let you know what happens.
2025 JOHN DEERE 408R LOT IDENTIFIER 10 (A53084)
2025 JOHN DEERE...
2024 KUHN SL124T LOT IDENTIFIER 60 (A53084)
2024 KUHN SL124T...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53472)
2012 RAM 5500...
2019 JOHN DEERE XUV835M LOT IDENTIFIER 25 (A53084)
2019 JOHN DEERE...
