ztrjim
thanks for all the great info!
With a few LED lights, you can certainly get by with a lot less power....and batteries.....but throw in refrigerator and air compressor, you're up to a fairly decent size system.
A 20v5amphr battery, for example, could run (assuming zero system loss) 100w for an hour, or 50w for 2hrs, and so on. You could run a couple of low watt LED for several hours. That is quite doable.
If you can make do with just LED lighting, then install a 10 watt solar panel and hook directly to a removed from service auto battery (assuming there's still some life in it). With a panel that small there's not need for a charge controller. System cost, excluding LED light, $35. Add a nice LED flood (see ebay) for another $35.
That's more or less what I did for a shed of mine that's far enough away from the house to make trenching in AC non-practical. Just used one of those battery maintainer solar panels, an old car battery and several cheapie LED "driving lights" I picked up at Walmart. Just the lights and an old car radio. Does the job. It's been there maybe 4 years now, still works just fine with the original battery.
Obviously, you're not gonna run power tools, refrigerator, etc. on a setup like this.
We have hit 2 " HP mains while pulling curb , It was in the concrete . Locator said minimal 2 ft of cover or it is not a liability .How far is the shed from your house or source of power? Crossing the gas line is just a matter of digging it by hand. I just ran water and power across my gas line Thanksgiving weekend. It took a few hours, but I dug 20 from where I thought the gas line was in both directions with a shovel for a total of 40 feet. I went two feed down and never found the gas line. I'm guessing it was about three feed down, I've heard it's supposed to be four feet down. I just don't trust the people who install those things to go as deep as they are supposed to. I've seen on the news where contractors have hit them at less then two feet.
For all the money this is going to cost you, digging the trench and running wire always makes more sense to me then dealing with solar panels and batteries. Especially knowing that the batteries are temporary.
The other option is to not have anything plugged in there and just get a small generator for when you do need power. I have a little Honda 2000 generator that starts easy, is fairly quiet and runs all day on a tank of gas.
Eddie
