B2400 API oil spec in the ownes manual
   / B2400 API oil spec in the ownes manual #1
Racer11
Member
Mc Louth, Kansas
Kubota 2400 jd 4240
Time to change my oil and I noticed that my owners manual says to use API CC/CD rated oil. Mobil 1 now offers zero rated oil 0-20 and 0-30,,,that sounds good for winter start ups in my unheated barn.
I would like some in put to using 0-30 Mobil 1 in the engine rather than a diesel rated oil,,something the owners manual does not recommend.
   / B2400 API oil spec in the ownes manual #2
CC/CD is diesel rated oil. See if Mobil 1 makes a 10W30 CC/CD Rated oil and if so use that year round.
   / B2400 API oil spec in the ownes manual #3
Kubota's manuals are woefully outdated on oil specs.
The current diesel spec is CJ-4,superceeding CC/CD.
Kubota factory fill is 10W30 conventional oil.
This would serve you well in Kansas,Shell Rotella or Kubota 10W30 are easy to find.
If you desire a lower viscosity synthetic oil for easier starts,5W40 CJ-4 oils for diesels are plenitful.
Shell Rotella,Mobil Delvac,etc.Any would be fine.
The Mobil 1 synthetics you mentioned are gas engine oils and don't have the capability to handle the soot load diesel engines require.
Good Luck!
Number two,,,,,Thank you sir, that answers what I needed to know. The Shell Rotella 10-30 will be my fill this weekend.
   / B2400 API oil spec in the ownes manual #5
Also, all CI-4, CI-4+, and CJ-4 oils are backward compatible. They can be used in CC, CD, CF, designed engines with no problem.
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
J and L Cargo Express Shadowmaster Enclosed Trailer (A55218)
J and L Cargo...
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2016 Hitachi XZ300LC-6 (A47477)
2016 Hitachi...
