Front headlight wiring question--Ford 1600
   / Front headlight wiring question--Ford 1600 #1
Anselcop
Monticello, Mn
Ford 1600 4x4
I'm replacing the cracked and broken light switch on my Ford 1600. I found a generic push/pull 2 position light switch I will be installing. Here is my question; There are two wire going from the current light switch to the front headlamps; a red and a yellow wire. Do both of these wires carry power to the headlamps? I connected the red wire to the new light switch and left the yellow wire disconnected and the headlights come on when I pull the switch.....what would be the function of the yellow wire? I was just planning on securing both the yellow and red wires on the same terminal on the new switch but I don't want to cause issues so I thought I better seek some advice before I did so.
Dan
   / Front headlight wiring question--Ford 1600 #2
Dan
According to the wiring diagram in the parts book, the yellow is for field lights, but it shows it going to the back implement light. The diagram does show two wires on the headlamps most likely hi-beam and low-beam.
I do have another yellow going to the rear for the field light; I guess I never thought of a tractor having high/low beam headlamps. I will take a closer look at the actual headlamps tonight to see if they are high/low style lights......thanks
   / Front headlight wiring question--Ford 1600 #4
For what it's worth, although your 1600 is a little older than my '89 1720, this 1720 does have high & low beam headlights..... :2cents:
BarnieTrk :thumbsup:
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A52748)
2023 NEW HOLLAND...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
