TNhobbyfarmer
- Joined
- Dec 23, 2004
- Messages
- 1,185
- Location
- Middle Tennessee
- Tractor
- Kubota L3430 Polaris Ranger 500
First a little background. My old trusty Stihl 025 recently started running very hot. After a few minutes of use, smoke would seep out from under the sprocket cover and the bar and chain would get very hot to the touch. Cutting would become very difficult even with a new chain. I thought it was a bar oil pump problem, but I determined that the chain was getting adequate lubrication. Since the saw is pretty old, and I suspect a trip to the shop would probably get pretty pricey, I decided to purchase a new saw, another Stihl.
I decided to read the manual of the new saw to possibly learn something new. The section on fuel indicated something quite interesting. It said that if you change from fuel with ethanol to non ethanol fuel or vice versa it will cause the saw to run hot. That's exactly what I recently did. I have heard so much about how bad ethanol is for small engines, I switched over to non ethanol. Could that possibly be the problem? Do any of you have knowledge of this phenomenon?
I am thinking of mixing up a gallon of ethanol fuel and see if the old Stihl cools down and starts operating properly again. Give me your thoughts. It kinda sounds odd to me, but I feel confident that the engineers at Stihl know of what they speak.
