Can quick hitch for BX FEL be added later?
   / Can quick hitch for BX FEL be added later? #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
Looking at a used bx25 that I don't think had this option can it be added and how much?
   / Can quick hitch for BX FEL be added later? #2
Depends on your skills. You can buy the QA head for the FEL arms for around $350. If you have the skills you can then modify your existing bucket pretty easily. If you don't have those skills a metal fab shop can do it for you. If you don't have one of those around you'd hafta buy a QA bucket which would be the most expensive route. A few minutes on Google would tell you the cost of a bucket. And the cost of the QA head if you search.
   / Can quick hitch for BX FEL be added later? #3
I think the Kubota BX QA uses the stock bucket.
Bruce
   / Can quick hitch for BX FEL be added later? #4
Hmmm.. Not sure how that would work. A "pin on" bucket wouldn't have the saddle necessary to use the QA head. We're probably talking about two different things??
   / Can quick hitch for BX FEL be added later? #5
Yeah, I went back and reread his question.... Now I'm thinking he's talking about a "quick" ability to remove the entire FEL??? I was thinking converting the bucket to QA. My bad. :confused3:
Sorry Im not talking about the entire FEL I mean the bucket, The quick attach is an option right?
   / Can quick hitch for BX FEL be added later? #7
Here is a photo of the QA from the Kubota website.
There have been several threads on TBN about using it on older tractors. It works.
Bruce
   / Can quick hitch for BX FEL be added later? #8
I think the other way and feel he is looking for a ssqa. That way you have a whole bunch of attachments you can either own or rent. The one off stuff is no good no matter if it is a green or orange system.
   / Can quick hitch for BX FEL be added later? #9
He did call it an "option" on a BX25, so that sounds like the Kubota BX QA.
I, too, wish they had done a lightweight SSQA or Mini-SSQA instead.
Bruce
   / Can quick hitch for BX FEL be added later? #10
So what SSQA attachments could he rent at the local rental yard that the BX could operate effectively? The Kubota QA and JDQA setup has a place in the market for these smaller machines.
2013 Yamaha Golf Cart (A51573)
2013 Yamaha Golf...
2020 BERGMANN C815S DUMP TRUCK (A51246)
2020 BERGMANN...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
UNUSED FUTURE FT-SE61 65" SWEEPER (A51248)
UNUSED FUTURE...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
2021 JOHN DEERE HX14 LOT IDENTIFIER 14 (A53084)
2021 JOHN DEERE...
