Can quick hitch for BX FEL be added later?
   / Can quick hitch for BX FEL be added later? #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
Looking at a used bx25 that I don't think had this option can it be added and how much?
   / Can quick hitch for BX FEL be added later? #2
Depends on your skills. You can buy the QA head for the FEL arms for around $350. If you have the skills you can then modify your existing bucket pretty easily. If you don't have those skills a metal fab shop can do it for you. If you don't have one of those around you'd hafta buy a QA bucket which would be the most expensive route. A few minutes on Google would tell you the cost of a bucket. And the cost of the QA head if you search.
   / Can quick hitch for BX FEL be added later? #3
I think the Kubota BX QA uses the stock bucket.
Bruce
   / Can quick hitch for BX FEL be added later? #4
Hmmm.. Not sure how that would work. A "pin on" bucket wouldn't have the saddle necessary to use the QA head. We're probably talking about two different things??
   / Can quick hitch for BX FEL be added later? #5
Yeah, I went back and reread his question.... Now I'm thinking he's talking about a "quick" ability to remove the entire FEL??? I was thinking converting the bucket to QA. My bad. :confused3:
Sorry Im not talking about the entire FEL I mean the bucket, The quick attach is an option right?
   / Can quick hitch for BX FEL be added later? #7
Here is a photo of the QA from the Kubota website.
There have been several threads on TBN about using it on older tractors. It works.
Bruce
   / Can quick hitch for BX FEL be added later? #8
I think the other way and feel he is looking for a ssqa. That way you have a whole bunch of attachments you can either own or rent. The one off stuff is no good no matter if it is a green or orange system.
   / Can quick hitch for BX FEL be added later? #9
He did call it an "option" on a BX25, so that sounds like the Kubota BX QA.
I, too, wish they had done a lightweight SSQA or Mini-SSQA instead.
Bruce
   / Can quick hitch for BX FEL be added later? #10
So what SSQA attachments could he rent at the local rental yard that the BX could operate effectively? The Kubota QA and JDQA setup has a place in the market for these smaller machines.
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53472)
DeeZee Crossover...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
FRONTIER LP2196 LOT IDENTIFIER 101 (A53084)
FRONTIER LP2196...
Golf Cart (A51694)
Golf Cart (A51694)
2012 TRAVIS 39FT DUMP TRAILER (A53426)
2012 TRAVIS 39FT...
(1) HD 26ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 26ft x 24ft...
