Ford releases fuel numbers for the new F-150
Status
Not open for further replies.
   / Ford releases fuel numbers for the new F-150 #351
Aluminum engines and body's started in 1902 Marmon , full aluminum body by 1907
   / Ford releases fuel numbers for the new F-150 #352
No. At the end of the day they will all go to a carbon fiber composite. Whether or not every brand will go to Aluminum first is the real question.
Right on. Just like the airplane development.
   / Ford releases fuel numbers for the new F-150 #353
I don't think carbon fiber would make for a good material in a truck bed.
   / Ford releases fuel numbers for the new F-150 #354
I'm not so sure about that. The airplane I fly has a Carbon Fiber Floor. We can configure the cabin with what we call a combo interior. This leaves in the 6 front seats and carpet but removes the rear ones and carpet exposing the bare floor. I have loaded pallets weighing 2000# on it then slide it into position. We hauled home a 1200# Elk, numerous tools and supplies, ect. I find it very forgiving, durable, dent resistant, ect. I would have no issues with a truck bed made of it.
Chris
   / Ford releases fuel numbers for the new F-150 #355
Chris
Carbon fiber is not a good material where impacts take place. Great for most other applications. It is brittle and will crack and chip rather than dent. If used with a bed liner to absorb impacts, then it would work.
   / Ford releases fuel numbers for the new F-150 #356
Not to mention the chips can be razor sharp.
   / Ford releases fuel numbers for the new F-150 #357
You might see some body panels from carbon fiber but you will never see anything that takes regular abuse made from it.
As an engineer in the aircraft industry I think the stuff is crap. Don't buy the line that it's lighter than aluminum either. For the same thickness it is but to get the same strength it is much thicker. It has it's place but primary structure or anything taking abuse loads is not one of them.
And people are worried about galvanic corrosion in the new F150? Introduce carbon fiber and it gets much worse.
   / Ford releases fuel numbers for the new F-150 #360
I had so many unpredictable failures with carbon fiber on mountain bikes and motorcycles, that I refuse to fly aircraft made of it.
One moment the carbon bit looks fine, another moment and catastrophic failure!
Status
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A53422)
2012 Chevrolet...
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
