in need of china tractor starter Fengshou estate 180
   / in need of china tractor starter Fengshou estate 180 #1
pastorjakes
mexia,al
Fengshou Estate 180
i have a Chinese tractor. JIANGXI TRACTOR built by Jiangling In need for a starter. This is a two cylinder diesel engine j285 18hp engine.
   / in need of china tractor starter Fengshou estate 180 #2
E-bay would be my choice. Bought knock off Stihl chainsaw parts shipped from China in under two weeks.
   / in need of china tractor starter Fengshou estate 180 #3
good morning can you see iff there is a part number on the starter most china built starters have numbering that start with the letter "Q" or can you post pictures of it
   / in need of china tractor starter Fengshou estate 180 #4
You'll probably get better answers in the Chinese Tractor forum.
I just replaced the starter on my Jinma and your best bet is to start with a part number but even with a part number you have to take measurements, Chinese manufacturers seem to have no problem giving the same part number to substantially different parts. I found the Circle G website (QD1401 Starter | Jinma, Farm Pro and Nortrac Tractors | Circle G Tractor Parts) very helpful because they have the critical dimensions for each starter they sell.
   / in need of china tractor starter Fengshou estate 180 #5
Check with farm boys tractors. they have some odds and ends for Chinese tractors
call after 3/15/15 and ask for tim 423-349-4643
Contact Farm Boy's Tractors
If they don't have it then have it rebuilt
check out my 180 Dragon in the chinese tractor section
   / in need of china tractor starter Fengshou estate 180 #6
Follow the links to see how the advice I gave to another forum member proved to be useful in getting a starter when all else failed.
http://www.tractorbynet.com/forums/...r-motor-zen-noh-zl-post488890.html#post488890
I would suggest you visit small starter/alternator repair shops and bring your starter with you.
Starters are often designed by one company and used by many manufacturers.
The repair guys recognize the starters and can find replacements or fix them whereas looking on the web using tractor model numbers can be unsuccessful for less common machines.
The owner posted the outcome of his search for the starter.
I was able to get the solenoid from a starter, alternator rebuilder in a nearby town after the kubota dealer said he could not help by matching the parts. The starter repair shop knew it by sight and $30 later it was done.
BTW the tractor is a Zen noh L1500DT motor is a 2 cyl diesel model number 17330
Dave M7040
Thank you for all the replies. The bad part is that the starter was stolen from tractor and thats is the reason why i am replacing. i dont know the stater model number all i know that the tractor is 18hp Estate 180 ... The Estate 184 tractor was built in China by Fengshou/Jiangling for Estate (Fengshou). It features a 18 hp (13 kW) engine.
SELLICK S80J4E-4PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-4PS...
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
1270 (A50490)
1270 (A50490)
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
Genie GTH-644 (A50490)
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
