fish6942
Gold Member
I just installed my new-to-me BX2750C on my BX2350. After reading up ahead of time, I was skeptical of Kubota's original idea of mounting the chute rotate handle to the FEL joystick. After using it once, I was convinced it was a bad idea.
So I looked over the right side of the machine trying to figure out a better way of mounting the rotate handle and came up with this. I ended up using a piece of 3/8" thick, 3" wide aluminum bar stock and mounted it to the FEL bracket. You'll notice I had to add a stack of washers for the bottom mounting bolt (circled in the picture).
If by the end of the season I don't make any more modifications, I'll probably cut the top end down some and paint it.
If anyone tries this, note that the handle will slide in and out quite a bit as the blower is raised/lowered. Make sure you account for this to ensure the handle doesn't hit the FEL joystick and that there is room to rotate the handle.
