Kubota alternator problems
   / Kubota alternator problems #1
ACE108
New Brunswick
Too many to list
I have a Kubota M108x tractor which I have been using to push and blow snow. Its been working great for about 6 years up until now.
There is about 1600 hours on the machine and the Alternator started heating so bad on it that it burns the belts right off. The machine can be idling and the temp still climbs. We put in a new battery, ran a new ground cable from the battery directly to the alternator, then put in a new alternator and still having the heating issue. We checked the amp draw from all the accessories and its all normal. the temperature on the alternator runs up to 260 degrees celcius compared to about 115 degrees on the other kubota 's I have.
I took it to the dealer today and they seem to be stumped as well. They told me I need to replace the pulleys, V-belt and tensioner which didn't make any sence to me. especially when its being replaced with another V-belt.
Anyways just looking to see if anyone else has run into a similiar problem or know what can be causing it ????
   / Kubota alternator problems #2
Have you measured the amps the alternator is putting out while running? Maybe a short from the main alternator wire to ground.
   / Kubota alternator problems #3
Does it run a separate regulator or is it internal on the alternator?
Have you checked the voltages off, idling and running? Looking for over voltages.
   / Kubota alternator problems #4
had a problem with Kubota alternator . removed from tractor and took to repair shop.
As walking into the shop the repairman asked if it came from Kubota told yes he said will be shorted armature and to get replacement be cheaper to purchase a new one. Tested and it was shorted he showed me a 1/2 of pick load all; Kubota. tossed into the pile.
Check on e-bay and a company that makes a replacement for carrier freezer trailers direct replacement.
ken
thanks for the reply guys, I'll keep you informed whenever we figure it out
   / Kubota alternator problems #7
ken
Must be a whole lot of Kubota's in that town if he has a half pickup load. Just saying
   / Kubota alternator problems #8
You have an alternator temperature gauge ? Sounds like bad bearings .
   / Kubota alternator problems #9
He is on Hwy 64 West of Morrilton , Ark and has a radius of over 50 miles of farm logging and gas/oil field equipment.
Now old men and women with more work than wish for. since the young men don't want to work with there hands getting dirty.
ken
   / Kubota alternator problems #10
Put a straight edge from pulley to pulley and see if their lined up right, could be a seized tensioner also.
KOMATSU WA270 (A58214)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
Motorcycle (A59231)
Motorcycle (A59231)
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
