Whats needed to have rear hydraulics on 4700?
   / Whats needed to have rear hydraulics on 4700? #1
Edward. S
Somewhere
John Deere
On our 4700 CUT it needs hydraulics on the rear. Is there a kit? Is it possible for someone to help me out to find out whats needed? On the tractor there is nothing there. So I assume it needs a joystick and everything... Thanks everyone.
   / Whats needed to have rear hydraulics on 4700? #2
Depending on how your tractor is set up you will either need this John Deere - Parts Catalog or this John Deere - Parts Catalog.
I'm only assuming this I don't know for sure but I would think that if you already have a joystick for a front end loader then the second kit would work. At least that's the way it was on my 4410. Otherwise you will probably need the first kit. Chances are they are no longer available from John Deere but you can order the parts individually. Of course it's more expensive that way.
You can try googling the part number for the kit. I was very fortunate to find a mid pto kit for my 4410 that way. I just did it for the fun of it and found a kit 2.5 hours away for $250. I couldn't say no. Good luck
The links don't lead anywhere. I don't have a joystick or anything.
   / Whats needed to have rear hydraulics on 4700? #4
Enter 4700 in the model search box.
Choose 4700 compact tractor.
Then pick hydraulics in the Sectional Index.
   / Whats needed to have rear hydraulics on 4700? #5
Your best bet may be to make a trade up for a tractor with at least the FEL as the dual SCV for the loader comes with a 3rd SCV to tie into for the rear hydraulics.
Be tough to start off without the basic valve setup. However, maybe it is still on your tractor and ready to tap into for all three functions.
   / Whats needed to have rear hydraulics on 4700? #6
Okay, I'll look to see what they have on there.
Not wanting to trade up tractors because right now its set up for row cropping. Needing something to run a hydraulic motor on the rear for a side dresser.
Found a Single SCV kit on eBay for $500. Part # BM19585. Looks pretty decent, if you guys need one they have 4 left.
   / Whats needed to have rear hydraulics on 4700? #9
A pic of a 4700 row crop would be great. Pls post one for us.
For a hyd. motor, then seems just tapping into the hyd. system would work for you. But I suspect the basic valve bank is there and ready to be tapped.
Here you go :) Its just used to go between the rows at the farm.
I don't even think it has that block. I'll just order the kit on eBay.
TPM 20K Mini Excavator (A47809)
TPM 20K Mini...
2013 PETERBILT 367(INOPERABLE) (A47001)
2013 PETERBILT...
2011 Chevrolet Silverado 1500 4x4 Pickup Truck (A46684)
2011 Chevrolet...
TPM 16 Mini Excavator (A47809)
TPM 16 Mini...
2022 ALLMAND NIGHT LITE (A47001)
2022 ALLMAND NIGHT...
2020 PETERBILT 579 TANDEM AXLE SLEEPER (A43003)
2020 PETERBILT 579...
