ZD 326 Rear Weights
   / ZD 326 Rear Weights #1
Kubota 2007
PA
Kubota L4740,B3030,ZD326, RTV900,L4200 1120RTV,L4310 & KXO4-5.JD 310SG,310J,JLG 450AJ. 0-5
Kubota has brackets and weights that mount on the rear of the ZD Mower, has anyone installed these weights on your Zero Turn, if so do you notice any stability or traction improvements?
   / ZD 326 Rear Weights #2
I have seen them on the front if the vac is installed, don't think you would need any more on the back . I put a JRCO blower buggy on the front of my ZD221 48" with a Skag 9hp blower , still didn't need more weight in the back.
   / ZD 326 Rear Weights #3
I think if you are looking for better gripping, you need to look into the tires. I keep saying I'm going to buys some different tires, but never have.
   / ZD 326 Rear Weights #4
Yes they are available. But I don't know of anyone that runs them. My ZD is rock soild on side of hills. The thing weighs around 1700 lbs so I don't see need for more weight.
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
John Deere 5100M (A53317)
John Deere 5100M...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2011 Freightliner M2 112 Tri-Axle Dump Truck (A55852)
2011 Freightliner...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
