Anyone Plow With A Double Middle Buster?
   / Anyone Plow With A Double Middle Buster?
I like the way his set up is adjustable for different tire widths...
   / Anyone Plow With A Double Middle Buster? #12
The Lister or Middlebuster was used almost exclusively in early days for planting row crops as in corn, milo etc. Cultivation being possible up to a certain size of the plants preserved moisture, covered small weeds to their death and at the same time filled soil in around the plants.
Word Origin
noun
1.
Also called lister plow, middlebreaker, middlebuster. a plow with a double moldboard, used to prepare the ground for planting by producing furrows and ridges.
2.
Also called lister planter, lister drill. a lister plow fitted with attachments for dropping and covering seeds.
   / Anyone Plow With A Double Middle Buster? #13
Like sixdogs says, a chisel plow would fit the conditions just fine. They are heavy duty, easy to find and easy to get parts. For that size tractor, I would think a double or triple middle buster might become bent quite easily. Most middle busters are Cat 1 that I have seen. Your tractor is at least a Cat 2. If you have hydraulic ports on your tractor, a chisel on wheels (transport chisel) would work very well.
   / Anyone Plow With A Double Middle Buster? #14
You could just make a ripper , with box blade ripper's , like I did , ( actually mine is converted from a double gang pull disk frame that was later converted to a single gang 3 point disk ) . I do have very clay type soil , Make 1 pass around perimeter of fence to break soil , then 2 passes with my KK 6'5 disk . This gives me a 8' to 10' wide fire break around West , South , and East sides of Property .
It is nothing fancy , but it works .
Fred H.
   / Anyone Plow With A Double Middle Buster? #15
Pulling 2 middle busters with a 75hp tractor seems like a waste of time to me. The photo of the three on the toolbar earlier in the thread looks like they are mounted on a <50hp 2wd Ford. With that much HP, you should be able to till a lot more land per swath than with 2 middle busters. Something like a 8' or 10' chisel plow, or 10-14' disc I'd think, though admittedly that's bigger scale than I'm used to, so I don't really know what the limits would be.
   / Anyone Plow With A Double Middle Buster? #16
Yes, a 75hp tractor will pull a lot more than a 2 bottom middle buster.
The question is why are you wanting to break up the soil with a middle buster? Or am I misinterpreting your question?
A chisel plow is the right tool to break up the soil with, then a disc harrow to kill the vegetation and smooth it out somewhat. Then a harrow if you still have clods that need to be broken up. And, finally, the middle buster to create the hills and furrows for planting.
   / Anyone Plow With A Double Middle Buster? #17
About two horsepower for two furrows:
or lots more:
Bruce
   / Anyone Plow With A Double Middle Buster? #18
For the record, a 75HP 4WD tractor that weighs 8,000 lbs and excellent tire tread will pretty much pull an 8 shank chisel plow. 7 shanks would pull better.
   / Anyone Plow With A Double Middle Buster? #19
My family did most of the work here on the farm in the last 45 years using small 20 HP to 40 HP tractors to do work that really required larger machines, but all was done well just taking a lot more time. I have a large field I need to plow soon and then level out with a disc and then tooth harrow. I have recently upgraded to a 75 HP NH and was wondering how well it might pull a 2 plow middle buster rather than a single plow. Any advice with a double plow or is the work similar? I have looked on line locally for new and used double middle buster plows and have had no luck so far. Down here they appear to be as rare as hens teeth!
What kind of soil are we talking about here? How deep is the good topsoil?
For example, the good soil on my 10 acre place is only about 5" deep. Not deep enough for a moldboard plow which will just flip the soil and move the clay to the surface burying the good soil. So I use an offset disc for primary tillage followed by a tandem disk/drag harrow combination to bust up the clods and smooth the surface for planting.
This is a 45 year old pecan orchard with 850 foot irrigated rows 50 feet apart. Over the years the 50 foot open areas between each row of pecans has become uneven, slightly rutted and full of small divits where mowing has become tiresome bouncing up and down while mowing. The orchard is in the front of our property and folks drive through it to get to our house so I keep it more "park like" and manicured. From everyone's posts I gather my offset disc harrow weighted down might do the job quite well without plowing first. My new tractor.....T4.75.... Weighs considerably more than my other tractors and has a air ride seat so it will probably do just fine as far as ride. The problem with buying a new tractor in the Winter is that I do not have much to use it for right now whereas in the warmer parts of the year I'll add about 250 hours to the meter each year. I only need to break the soil up about 3" down and then smooth out so maybe the plow would be a bit extreme.
2023 BOBCAT T76R SERIES SKID STEER (A51242)
2023 BOBCAT T76R...
(10) 8' Treated Posts (A50515)
(10) 8' Treated...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
New Calf Hut (A50515)
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
