Electric Diverter kit, 4120 to 4720
   / Electric Diverter kit, 4120 to 4720 #1
Keoke
Gold Member
northern calif.
JD-970
Hi folks, is there anyone out there with this kit intalled on their tractor? Part # LVB25511. I understand that this kit provides for four quick connectors at tractor rear. These connectors can be used to operate tip and tilt by using the joystick. Do I have this right? A picture of this set up would be great.
take care,
   / Electric Diverter kit, 4120 to 4720 #2
Keoke,
The kit allows the joy stick to control two functions. The joy stick controls the loader normally. When you switch the rocker switch it controls the rear SCV's. You can hook up what ever you want to the SCV's.
Ron
   / Electric Diverter kit, 4120 to 4720 #3
There is a button up front that transfers operation from the front end loader to the rear remotes. I loved my set-up. I have one on my 4310 and on the 4720 I just sold. The cab 4720 will have this set-up also. Here is a picture of the rear SCV's and top-n-tilt.
   / Electric Diverter kit, 4120 to 4720 #4
does anyone have a plumbing diagram for this part lvb25511, mine doesn't work. Need help.
   / Electric Diverter kit, 4120 to 4720 #5
This might help
  • Diverter.pdf
   / Electric Diverter kit, 4120 to 4720 #6
I have the kit on our 09, for full rear functions to have two extra functions for a top link and side tilt on a box blade... but havn't used it in a long time until a month or two ago, the button comes on "lights up" and nothing happens... so maybe the solenoid is bad.. we have the trans ripped apart right now so its easily accessible, will check it before we put it all back together.
   / Electric Diverter kit, 4120 to 4720 #7
Update I took mine to the dealer and they found out that the valves were stuck from lack of use.The solenoid was fine
   / Electric Diverter kit, 4120 to 4720 #8
It is a very good idea to cycle these diverters everytime you use your machine...the tolerances are so tight that the slightest bit of corrosion will cause them to stick.
   / Electric Diverter kit, 4120 to 4720 #9
Hello everyone, I'm in need of a plug/connector for a 2007 New Holland T2410 Tractor The safety controller shorted out and burned the plug/connector that plugs into it.new Holland tells me a complete wiring harness will be needed. No luck from any New Holland Dealers. A used one will be fine.
   / Electric Diverter kit, 4120 to 4720 #10
Why are you posting in a John Deere forum on a thread about an unrelated issue on an unrelated tractor? There are more appropriate forums here on TBN.
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2007 KENWORTH W900L DAY CAB (A52472)
2007 KENWORTH...
2014 Chevrolet Tahoe (A52377)
2014 Chevrolet...
