John Deere quick hitch
   / John Deere quick hitch #1
Duck95
Livingston Tn
John deere 5045d
Hey guys! I have a John Deere 5045d an I wanting a quick hitch but which would be better the i match or a regular quick hitch? All it would be used on is my 6ft bushhog, box blade an hay spear? Thanks guys
   / John Deere quick hitch #2
I have the imatch. I love it. Don't know if there's much difference between the different brands but I'm happy with what I have
Brett
   / John Deere quick hitch #4
The imatch is a quick hitch, it is just JD green. Are you looking for a cat 1 quick hitch or Cat2? Do they make a Cat 2 imatch? I have 2 cat 1 imatches and I like them. I would also look at the land pride quick hitches if you need a cat 2. In the cat 1 version it looks just like an imatch. The imatch is actually less than the Land pride quick hitch for the cat 1. I don't how much a cat 2 would be. I guess you know you have to have quick hitch compatible equipment.
Quick Hitches | Land Pride
There are also some cheaper quick hitches like the harbor freight Speeco knock off. The speeco quick hitches I have seen are not as nice as the imatch.
Here is a video I made comapring the harbor freight to the imatch.
Here is the imatch in action.
http://youtu.be/_eFc-puQ99A
   / John Deere quick hitch #5
I have the cat 2. Unless you need it, id stay with cat 1. My hitch has a sticker of 580 or something. They are proud of them. I needed cat 2 for my mx7
Brett
   / John Deere quick hitch #6
The cat 1 is $350.
   / John Deere quick hitch #8
I have two of the harbor freight cat 1 , and am very happen with them. One is mounted to a SSQA plate to use on loader and the other is on the 3pt. I looked at a I match the other day while getting a loader third function handle at deere dealer. I will say they have a nice fit and finish compared to the cheaper ones. But for 350 dollars they should have. 😄 that being said Mine has seen a bunch of heavy duty use and have had no issues.
   / John Deere quick hitch #9
My Harbor Freight quick hitch doesn't fit several of my implements -- mostly because the top link hook is too short. I'd say it is a 50/50 proposition. I would by an alternate, more expensive one if I had confidence it would fit better.
Is there a source for different shaped top-hooks? (I am not a proficient metal-worker!
   / John Deere quick hitch #10
It's not uncommon for a person with several implements to find that all will not hook up to a QH or imatch without modification.
Where I would be looking to make this decision is price. $350 for a CAT I hitch is terribly high. You can buy a very well built CAT II hitch for less in an off brand.
I use the snot out of my QH. It has to be well built and stout with quality materials. Being JD green with an imatch sticker does not guarantee that.
2014 Mazda Mazda3 Sedan (A48082)
2014 Mazda Mazda3...
2002 Fleetwood Expedition 36ft Motorhome (A48082)
2002 Fleetwood...
1271 (A50490)
1271 (A50490)
1042 (A50459)
1042 (A50459)
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2015 Chrysler 200 Limited Sedan (A48082)
2015 Chrysler 200...
