leonz
Super Member
Adding to the excellent comments above:
The pronovost PXPL86 fits within you power range-price is another issue.
it has the rear scraper blade and you can use it like pull behind dragging snow forward as is shown in their videos.
The issue is your mule period, and whether you can afford to upgrade to the next power class SIMPLY because you are POWER SHORT.
The other issue is your pocket book as it will be hard to buy a snow blower now unless you have an Allied Farm King dealer nearby.
The other issue is liability and how many times you are going to deal with a snow event(you would be surpized how many times a road gets plowed to meet DOT standards.
A bigger mule with a
cab
high end seating
HID lighting
loaded tires
chains
they will get stuck so be aware of that and have a heavy 4WD wreckers phone number handy
In the case of the PXPL 86
The REAR LIGHT ATTACHMENT
TIVAR poly scraper bar
1,000 rpm to 540 reduction gearbox
full flight auger(solid auger- A MUST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
commercially these things are are a must, BEEN THIER DONE THAT wish I could have done it this way.
You should plan on buyi9ng a least 2 million dollars in blanket liability coverage from somewhere as well.
cab
high end seating
HID lighting
loaded tires
chains
