YM 3000 Oil light coming on
   / YM 3000 Oil light coming on #1
auraaura
Member
Columbia, MS
Yanmar YM 3000
It just started today. Would come on when rpm's were below 1000, so I kept rpm's above that. After about an hour had to keep rpm's above 1500 for it to stay off so decided I'd better park it. What would be the best thing to check first ?? I'm thinking replacing the oil pressure sending switch would be a good place to start ? It would at least be a cheap place to start. Anybody got any suggestions?
   / YM 3000 Oil light coming on #2
Oil and filter have about 5 hours on them. I'm a little dumb on oil pressure gauges. Would just any old gauge from the auto parts store work as long as I got the adapter ?
   / YM 3000 Oil light coming on #4
Yep. In fact I already had a plumber's 100 psi water test gauge and the right adapters so I installed that temporarily to monitor pressure. This confirmed the engine was ok.
The replacement sender I bought was a generic Toyota/Honda/Subaru sender from Autozone; they have the same thread. Under $10.
Here's a longwinded post where I described all this:
Low oil pressure? No, bad sender!
144606d1257399170-low-oil-pressure-no-bad-p1550937roilgauge-jpg
Thanks for the help CA. I just ordered the tester from harbor freight. Will see if the adapters with their kit will work, if not will order Hoye's adapter. Here's hoping it's just a bad sensor and not something more serious.
(-: Oil pressure is good (see 50 + PSI reading on dandy new pressure gauge). Must be the sender. Thanks for the help. On an unrelated topic, anybody know where I could find a cap/cover for the center of my steering wheel--before the nut rusts to the shaft?
2000 FORD F650 SINGLE AXLE DUMP TRUCK (A52472)
2000 FORD F650...
1997 East Manufacturing Walking-Floor Trailer, VIN # 1E1U1X287VRE22897 (A51572)
1997 East...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
20" Sea Container (A47384)
20" Sea Container...
