how do I disconnect hydraulic coupling "FAST" is the make
   / how do I disconnect hydraulic coupling "FAST" is the make #1
Glenn K
Australia
Kubota BX2670
There are 4 hoses going into a FAST brand connector 2 banks of 2 and I have no idea how to disconnect them.:confused:
You push them in and pull them out:dance1:
   / how do I disconnect hydraulic coupling "FAST" is the make #3
Yes push in quickly then pull out quicker, all in one fluid motion. The brand name should be "FASTER"
   / how do I disconnect hydraulic coupling "FAST" is the make #4
Nice hydraulic pun, Kenny!! :laughing:
   / how do I disconnect hydraulic coupling "FAST" is the make #5
Here is the Faster definition.
PUSH PULL
QRC痴 that use this particular connection technology, which includes also other similar types such as:
Single-acting sleeve free to axially retract and free push, the sleeve of the female part is designed to enable it to operate a double effect: in fact, being equipped with a double housing for the connection spheres,it can be used both pushing that pulling the male coupler into the female coupler.
One of the prevalent application is the agricultural machinery industry, that have been adopting
this connection technology for several decades now.
AGRICULTURE
   / how do I disconnect hydraulic coupling "FAST" is the make #6
It helps to relieve the pressure by moving the control for that particular fitting ( implement) with the engine shut of before disconnecting.
2013John Deere 244J (A47477)
2013John Deere...
20'x20' High End Carport (A53316)
20'x20' High End...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
Informational Lot - Shipping (A55314)
Informational Lot...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
