Renze
Super Member
I believe the point you are not understanding is that in the past, many automatic transmissions for 4wd and 2wd vehicles allowed you to start out in second gear. There is an advantage to this because in 1st gear, it is difficult to apply really low amounts of torque to the wheels with your accelerator pedal. It is very unforgiving. 2nd gear allows better low torque control. 4WD or 2WD doesn't matter. I have had 4WD vehicles stuck in snow that would spin all 4 tires but with careful low torque easing of the throttle was able to rock the vehicle out.
What you describe also applies for gas engines with manual transmission. Whilst pulling a trailer on wet grass with my S70 TDI, i simply let the clutch up slowly in 1st gear without moving the throttle. The wheels spin one, two times, while the revs drop to 500 and there you go, rolling with static friction between the tires and the wet grass.. My neighbour is having a V70 2.5 10V gas, and he has to push the accelerator pedal, which makes him spin the tires fast enough to not stall the engine, giving dynamic friction between the tires and the surface, giving him less traction.
For the same reason my Diesel clutch lasts longer than a clutch in a gas vehicle. Its much easier to control spin (either tire spin or clutch spin) when the torque is controlled by the fuel injection, not delayed by the distance the mixture has to travel between throttle valve and combustion chamber, and what else
my family are horse people, and i remember my father hating the 740 2.3 automatic when they had to go with the horse trailer in a wet field that served as parking lot. you had to push the accelerator to generate torque at the rear wheels, but once you spin, the slip in the torque converter would change to slip at the tires, so that you had no traction at all anymore, and had to drop the revs to stop spinning and then increase the wheel torque again. Mostly you lost momentum. With his later 740 turbodiesel the speed was in relation to the accelerator pedal position, irrespective of tire grip. When he got a Camry 2.2 on LP gas after that, he started complaining again.
I have been offroading, climbing 45 degree hills with a front wheel drive car by relying on Diesel torque and a governor that keeps the revs under control if you loose traction for just a second.
Getting back about automatics taking off in 2nd: Why would anyone want to drive off in 2nd gear, with less torque at the wheels, and more slip in the converter ? Old farts that cant drive, can use the ESP to prevent doing donuts...
