Dealer has 3520 inbound... But
   / Dealer has 3520 inbound... But #1
nch209
Northern Virgina
John Deere 3520
Has 300x loader and smaller r4 tires. If I had the choice I'd go 300cx, and bigger r4 tires. Is it worth, if I make a deal on it, to try to trade and upgrade the loader to a cx or 165?
Also, are the current small r4's "sellable", wheels and tires, and then I can just replace with the bigger ones? Or is there a market for liking the smaller ones better where I could do a trade or is the preference for the small ones?
Thanks!
Nch209
   / Dealer has 3520 inbound... But #2
Thanks!
Nch209
Lot of discussion here on upgrading the 3000 series with larger tires and wheel spacers, etc. because of stability issues. So, I'd be surprised if you'd have alot of takers lining up!
Also, if you are buying a new tractor... Get what you think you want/need 'cause if you don't you'll always be wondering if you shoulda, woulda, coulda!
My $0.02
AKfish
   / Dealer has 3520 inbound... But #3
Thanks!
Nch209
I would get what I want at the time of purchase. I would not buy, then speind more money modifying to get what I should have purchased new.
Thanks for the insight. I'll check it out just because its so close, but still leaning 41/4320 route. Think a 4 series would suit better for the long haul. We shall see!
   / Dealer has 3520 inbound... But #5
Is this a used tractor coming in? If it is new the tractor and loader come from two different plants - at the dealership they decide which (if any) loader to install. In regards to the tires do not, I repeat DO NOT purchase a 3x20 series with the small R4 tires.
It's used. Inbound, and should have around 100hrs on it. Tell me more about why not to go small tires. I want big just for look, ground clearance and possible better lower ground pressure. Tell me more!!!!
   / Dealer has 3520 inbound... But #7
This fall, I traded in a 3032e [r4 tires] for a 3046r/cab [with the larger r4 tires] since that was how the dealer ordered it.
Other than the cosmetic fender-fill, I am unable to tell a difference in the tire sizes. I am impressed with the HP boost though of the 'r' over the 'e'.
I do notice more of a "bucking" going down our self-maintained road, but that may simply be the air-seat or the weight/balance of the 'r'.
[or a subtle hint to rebuild the road...]
Thanks for feedback. I'm considering this 3520, but also wondering if new 3039r may be better, and for the $$$, a leftover 4230 is appealing. How's your 46r so far?
   / Dealer has 3520 inbound... But #9
I am LOVING the 46r - going from open station to cab is a relearning experience since you are isolated from the elements, you have to look more - rather than "feel' your environment as you go.
[same as driving a car vs a motorcycle]
Deal went down tonight, and I pulled the trigger on the 3520. Fit me needs, still under warranty, and fit my budget. Didn't like the small r4s, so dealer is swapping for new big r4s with tires, rims, and methanol loading. Bummed about the 300x, but it's stIll light years ahead of the kubota la402 I've been ok with. Hope to see the tractor in a week or 2.
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2014 Ag Spray Schaben Sidedresser (A52748)
2014 Ag Spray...
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
