Ditch Bank Mower with Mahindra 5035?
   / Ditch Bank Mower with Mahindra 5035? #1
dhaymon
Member
Leesville, LA
2012 Mahindra 5035 PST
Anyone have experience with a ditch bank (offset rotary mower) on their Mahindra 5035? I am reading about them, but most seem to require cat 2 3 point and are at 50 hp or better minimum. I have a steep roadside ditch and three pond banks to maintain. I don't think my sickle bar is up to some of the saplings that grown there.
   / Ditch Bank Mower with Mahindra 5035? #2
The mower company doesn't want you to use to light a tractor as there is considerable weight hanging off of the side of the tractor.
   / Ditch Bank Mower with Mahindra 5035? #3
Check out the Ferri ZME 155. You have way more than enough tractor to run it and if it's anything like my conventional flail mower, it will happily chew up 1.5" saplings all day long.
I understand the rationale, but my tractor weighs more than a Kubota M7040...
   / Ditch Bank Mower with Mahindra 5035? #5
Use a chain saw on the saplings, then your sickle mower will be OK.
Bruce
   / Ditch Bank Mower with Mahindra 5035? #6
I understand that, but mower manufacturer knows that many of the lower HP tractors aren't heavy enough. I would be cool if they were to put into their specs the words "unless you are mounting the mower on a Mahindra".
   / Ditch Bank Mower with Mahindra 5035? #7
Ferri specs both a minimum horsepower and a minimum tractor weight on their mowers.
   / Ditch Bank Mower with Mahindra 5035? #8
   / Ditch Bank Mower with Mahindra 5035? #9
I too am interested in a boom mower for a 5035. I agree with the others, FERRI is looking like the best option. Here is a link
http://generalimp.com/sites/default/files/product-pdf/ferri_mowers_boom_small_hp.pdf I don't have any idea how accurate the prices are but it does cover the options very well. I'm looking at a Model TD-42.
I have loaded tires So I am well over the minimum weight requirements.
Those boom mowers are pretty awesome, but I was actually talking about the ditch-bank flail mowers:
DITCHBANK FLAIL CUTTERS | General Implement
They're a bit less expensive as long as you are mowing close to the tractor and you aren't trying to reach down over a fence or something.
   / Ditch Bank Mower with Mahindra 5035? #10
I wish I could get by with that kind of cutter. I need the reach of a boom mower. Either way Ferri has a good reputation. My problem is there are no dealer anywhere close to me.
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
ITEM LOCATION (A53084)
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
