Liquid Ballast In Radial Tires
   / Liquid Ballast In Radial Tires
I appreciate all the comments and recommendations. I told my dealer "DO NOT" put fluid in the rears. If I find that I need more weight, it will come in the form of wheel weights and a counterweight. Fluid in the rears will be the last option.
   / Liquid Ballast In Radial Tires #22
I think this decision gives you more flexibility as to what your needs will eventually be for the tractor. Let us know how your uses dictate your future decisions about ballast.
   / Liquid Ballast In Radial Tires #23
If you want to see if you need more weight on the rear, just put it in 2 WD and try backing up a slight incline with your loaded FEL. If the tires spin rather than grip, then you need additional weight on the rear. It may not look like it is light on the rear, but you can see rather quickly how much stress is on the Front wheel drive when you do this.
Recently my front wheel drive went out and I drained all the water from my tires in order to haul it to the shop without overloading my trailer.
With the FEL on, it wouldn't climb up the ramps when the trailer was on level ground, just spun the tires. I had to position the trailer at the bottom of a steep hill so the ramps were almost level in order to get it on the trailer.
With no weights, no ballast, no 4 WD and a FEL on a tractor, they don't have a lot of traction in the rear.
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A57453)
2007 International...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2014 International Derrick Digger Truck (A55973)
2014 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Toyota Camry Sedan (A56859)
2014 Toyota Camry...
Jumbo Quartz Slab 127.5" x 63.75" (new/unused) Est. Retail $2,200 (Pickup Location: Atascadero, CA) (A59225)
Jumbo Quartz Slab...
