When Shear Pins Don't - Broken Driveshaft Yoke
   / When Shear Pins Don't - Broken Driveshaft Yoke #1
zkurtb
North Idaho
Kubota B7800
I hit a rock with my Allied Buhler 60" snowblower. Not the first time, and the shear bolt has always done it's job. But not this time, even though it is the same grade of bolt. Something had to give. I guess I'm lucky It wasn't worse. Pictures are of the yoke that connects the driveshaft to the blower, it's what was sacrificed. The u-joint is still intact. Anyone know where to get replacements? I'm starting to call dealers, but guessing they may be expensive, wondering if there is an alternate source for these. It is a single keyed shaft, not splined.
   / When Shear Pins Don't - Broken Driveshaft Yoke #2
My first stop would be Tractor Supply. Should not be high dollar.
   / When Shear Pins Don't - Broken Driveshaft Yoke #3
TSC or Rural King. It isn't special unless it's metric but these two places should have those also.
   / When Shear Pins Don't - Broken Driveshaft Yoke #4
The dark discolorations on the second picture indicates that there was a fracture there for some time before the failure, probably from another shear incident. That's probably why the yolk failed before the pin.
Even when you get a replacement, I'd probably grind out and braze that one back together just as a backup, unless they're dirt cheap and you pick up one for a spare.
   / When Shear Pins Don't - Broken Driveshaft Yoke #5
Check your area for drive line repair shops, or, heavy duty truck parts places. Several HD truck parts businesses in our area, also do drive lines/pto shafts for large dump trucks, and other applications. They have about every size imaginable on hand.
   / When Shear Pins Don't - Broken Driveshaft Yoke #6
I believe Flyerdan has a good handle on the cause of this failure
Thanks for all the replies and insights. I ended up ordering from a retailer/dealer. Around $50. I had tried looking at TSC website TSC Yokes although I hadn't called them, and much other web searching, found lots of yokes but not this one. We do have a good heavy duty truck repair/parts shop where I get snowplow parts, hadn't thought about trying them for this.
The main challenge for brazing would be the loop for the u-joint that has been deformed and stretched open as can be seen in the second pic. I'm not an experienced welder/brazer though I've done a bit. The part being cast, I understand it would have to be preheated and slowly cooled to prevent cracking. Wouldn't hurt to try.
Interesting thought about it already being cracked, the rust discoloration does seem to indicate that.
   / When Shear Pins Don't - Broken Driveshaft Yoke #8
You need to make sure that you have a no code bolt as in no marks on the top. A grade 5 or 8 would be too hard for shear.
If shearing is rare you might go a bolt size smaller so it will shear easier to stop this from happening again.
It is a grade 2, as per manual specs. Think I'm going to replace it with another since it didn't give...
It's sheared a number of times in the past, so don't know why not this time.
378812 (A51573)
378812 (A51573)
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
1988 Ford F-250 Pickup Truck, VIN # 1FTEF26N1JNA71750 (A51572)
1988 Ford F-250...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
