BBQ Smokers
   / BBQ Smokers #131
   / BBQ Smokers #132
Just read all 14 pages. Great read! I plan to get my first smoker in the spring. Looking at a Weber Smokey Mountain Cooker.
   / BBQ Smokers #134
I have a Weber Smokey Mountain Smoker. For the money, it is as good as it gets. I also have a Big Green Egg, and the Weber will do as well as the BGE, but you have to tend to the water pan. Clean up for the Weber is also a pain.
   / BBQ Smokers
Good choice, I have one, but one reason I got the large side fire box one was the lack of room on the WSM. If you do get the weber, get the 22.5 inch one instead of the 18.5. I can't even get slabs of ribs to lay flat on my 18.5 because they are to long. Another reason I chose another smoker is if your using the top and middle rack on the WSM you have to remove the top rack and food to get to the middle rack. Just gets annoying depending on what your smoking.
   / BBQ Smokers
Been meaning to update this thread with some recent cooks
Beer brats poached in beer
Sliders
   / BBQ Smokers #139
Well I didn't get my Weber, but I was in Home Depot for something else when I spotted this;
Brinkmann Smoke 'N Grill Charcoal Smoker and Grill-810-5302-S - The Home Depot
$90 canadian. Figured I couldn't go wrong. Found some interesting mods on youtube such as putting in a real thermometer, putting the legs on backwards for easier access to the coal pan as well as drilling air vents in the pan for more air & heat. If it works out and I use it enough to make yummy meals it'll be easier to convince momma to get a nicer one. ;)
   / BBQ Smokers #140
Good luck with that. I had one; it wouldn't get hot enough. I used it once or twice and gave it to the Salvation Army. I had a similar one called the Cajun Cooker, and it was excellent.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A56858)
2006 International...
2014 Lincoln MKS Sedan (A56859)
2014 Lincoln MKS...
2005 John Deere 200C LC (A55272)
2005 John Deere...
2011 International WorkStar 7400 Terex Hi Ranger RM75 75ft. Bucket Truck (A55973)
2011 International...
(2) METAL WELDING STANDS (A58374)
(2) METAL WELDING...
