Mowing BX25D and a 5' rotary cutter?
   / BX25D and a 5' rotary cutter? #1
xzcVAbc5
Gold Member
Northeast KS
Kubota BX25D
Does anyone out there have any experience using a BX25D or similar with a 5' rotary cutter? I'm primarily interested in mowing tall grass along fence lines. The 5' width appeals to me so I can be farther away from the fence and so I know for sure I'd be done in two passes.
Looking at the weight I'm pretty sure there wouldn't be a problem. I'm more worried about having enough power.
   / BX25D and a 5' rotary cutter? #2
I have a 5' and picked it up with the BX. It was very heavy. I never have tried it on the BX. I would be worried about a 5' rotary cutter pushing a BX around. I would look at a sickle bar mower.
Here is a sicklebar mower on a BX. The guy is a member here too, I can't remember his name.
http://youtu.be/d9R6JM3iYwc
   / BX25D and a 5' rotary cutter? #3
I use a 5' land Pride rotary brush cutter on my BX 25. It works great, no problems, sucker will chop a 3" limbs to toothpicks in a heart beat. I use the FEL on the front to knock down the big stuff and then run over with the hog.
Ron
Ron
Which model of cutter?
   / BX25D and a 5' rotary cutter? #5
Jeff,
Sorry I mislead you, I have the 4' one, RCR1548. That's what happens when you get old. I had a choice when I bought it with my BX and chose the 4' rather than the 5' as the bill for attachments was growing fast. The way my BX w/the 4' performs I am sure the 5' would work also. Check the LP web site they have a very easy one to navigate and they state HP requirements for their implements. I cut 18" high field grass all the time with out a stutter, need two passes at right angles to get it all though. Run at min 2500 RPM engine speed though.
Ron
   / BX25D and a 5' rotary cutter? #6
I have an old 5' Ford rotary cutter that I use with my BX25 with no problem. It doesn't push me around and has no problem cutting on a hillside.
   / BX25D and a 5' rotary cutter? #7
IF you are comfortable with the weight, power shouldnt be an issue.
Mowing fence lines, you probably wont be buzzing around there at 5-6 MPH. Your tractor can go plenty slow enough for power not to be an issue.
   / BX25D and a 5' rotary cutter? #8
If you don't have a fel you would need some weights on front for balance . The power should not be a problem as my 2650 is about the same hp as yours and I run a 5 ft. lp med. duty cutter .
When you say "doesn't push you around" what does that mean?
   / BX25D and a 5' rotary cutter? #10
Tail wagging the dog as they say.
A big, long, heavy cutter has a tendency to "throw" around the back of the tractor when turning. Lots of inertia with plenty of leverage back there with too much cutter for the machine.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2008 CAT 287C (A50854)
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
