Slowing down hydraulic chute rotation on snowblower
   / Slowing down hydraulic chute rotation on snowblower #1
joe04785
Maine
XR3037
Hey all, I got a question about slowing down the rotation on a snowblower chute that is hydraulicly operated. I have been looking at installing an in line valve to slow the rotation of the chute. My question is do I need one in line valve or two in line valves, one for each line?
   / Slowing down hydraulic chute rotation on snowblower #3
I agree with J. J. (other comment) The only way to reduce speed or oil flow is by a valve (2 ways) or insert a smaller spooler in each line.
   / Slowing down hydraulic chute rotation on snowblower #4
The needle valve is simply a hand adjustable orifice so it works in both directions.
FYI - You will probably notice that the cylinder is faster retracting than extending. If for some reason this is not acceptable and you want to adjust the speed for each direction separately it is possible, but more complicated. Let us know and we can give a solution or two.
ISZ
   / Slowing down hydraulic chute rotation on snowblower #5
I put on 2 flow control valves. As the old expression goes " when in doubt meter out " When I am running the snow blower the engine is at rated PTO speed and the chute would really be moving to the point it could damage itself. If I remember correctly I used one way flow control valves. You get a difference in speed due to the rod diameter of the cylinder and you probably already know that. If you need the exact pt. number let me know but I used 2 because of the speed differential. Later
   / Slowing down hydraulic chute rotation on snowblower #6
I have a question on the same issue.
My Massey GC2310 piping is 1/4 NPT so I was planning to get this:
1/4 NPT 5 GPM PRINCE WNV-400 NEEDLE VALVE
Does this valve require proximity to the motor or can I place it in-line at the other end of the hose where it would be convenient (i.e. Needle Valve>elbow>quick coupler)
   / Slowing down hydraulic chute rotation on snowblower #7
That should work.
   / Slowing down hydraulic chute rotation on snowblower #9
Yes. -------------------
   / Slowing down hydraulic chute rotation on snowblower #10
Is your chute rotation via a hydraulic motor or a cylinder? If a motor you may want to install a flow control in each line metering flow into the motor and free flowing out of the motor. If just using a single flow control you will be pressurizing the shaft seal while rotating in one direction and could potentially blow the shaft seal out.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2022 Ford F-750 Super Duty Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A49461)
2022 Ford F-750...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2022 JOHN DEERE 332G (A50854)
2022 JOHN DEERE...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
