How much does my truck weigh?
   / How much does my truck weigh? #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I called my dealer and he said the build sheet says 4177 pounds. Does that sound right? I see guys here talking about 6, 7 & 8000 pound trucks. That is what got me to the question. Here are the specs.
2007 GMC 2500HD 4X4
extended cab
79 inch bed
6.0 V-8
gcwr = 16,000 lbs
gvwr = 9,200 lbs
   / How much does my truck weigh? #2
Could be but sounds a little light for a 2500 IMO. My 2007 dodge 2500 Mega with diesel engine and tools in the back weights just over 9k pounds.
   / How much does my truck weigh? #3
I would think more around 5k with the gas engine. Go to a truck stop with a scale and weight it up.
   / How much does my truck weigh? #4
My 2002 Dodge Ram w/ cummins, short bed - fuel fuel, me (190#) and a cross over tool box in the bed - weighed a tad over 7200 lbs..
   / How much does my truck weigh? #5
Your dealer is nuts. A stripped down, short bed, reg cab, 2wd is likely more than that.
There should be another sticker inside the door that has tire information. It will also list the payload capacity of the truck.
Take the 9200GVWR - whatever the payload sticker says and you have your answer +/- a few pounds. And ofcourse that dont account for whatever you added, tools, passengers, etc.
I am guessing somewhere between 5800-6200# empty
   / How much does my truck weigh? #6
Found one site that says 3353# payload and 5847# curb weight
   / How much does my truck weigh? #7
Yea, should be north of 5000lbs, my tundra weighs in at 5500 give or take after looking into it.
   / How much does my truck weigh? #8
According to NADA, a similar crew cab (not ext.) has a curb weight of 5857 lbs. Yours should be close.
2007 GMC Sierra 2500HD Crew Cab SLT 4WD Specs & Performance - NADAguides
A little more searching and I found this. 5847 lb. for the ext cab 6.0
www.nationstrucks.com
› Home
› Used Cars
› GMC
Jun 29, 2014 ... 2007 GMC Sierra 2500 SLE/Z71 Quad Cab 4x4 Truck Extended ... Overview; Tech Specs. Details. Bodystyle: Truck Extended Cab; Engine: 6.0LL V-8 cyl ... Exterior height: 1,952mm (76.9"); Curb weight: 2,652kg (5,847lbs) ..
   / How much does my truck weigh? #9
Does the title and or registration not have a GVW stated?...I thought some states used the GVW on the title to determine how much the tag tax is...?
   / How much does my truck weigh? #10
Your in Iowa,there has to be a grain elevator fairly close,go there & weigh it & you will know then.
2016 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A56138)
2016 VOLVO VNL64T...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
CATERPILLAR 299D3 SKID STEER (A52707)
CATERPILLAR 299D3...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
