Bucket Trucks
   / Bucket Trucks #11
A lot of times at job sites you'll see them raised with a generator or some other expensive piece of equipment dangling from them, to keep them out of the hands of thieves.
THIS !! Being a retired electric lineman I have spoke to contractors why they leave there booms in the air.
   / Bucket Trucks #12
I used to work for an electric utility in MA, but usually tried to avoid going near work on the weekends, so I'm not sure we had a practice of leaving buckets up. Nothing is ever left in buckets as far as I know, nor equipment hung off them to guard against theft. The only reason I can think of to put the buckets up for the weekend is if you find any have come down on Monday morning it's time to look at the hydraulics for leakage in the system.
   / Bucket Trucks #13
As I stated in an earlier post lineman leave their hand tools ( bucket tools ) in the toolboard inside the bucket, the upper boom is raised so the bucket is not easily acessible to theives and bandits, I've worked all over the country and have never worked for a power line construction contractor or utility that takes everything out of the bucket everyday, tree trimming outfits different story. Charlie.
   / Bucket Trucks #14
Agreed! I'm an old retired Lineman who used to operate a double bucket truck for several years and leaving the boom raised would often be done for security reasons, both to keep thieves away from the tools and also to eliminate the possibility of people (more so kids) falling and injuring themselves while climbing in or out of the buckets and then suing the corporation.
   / Bucket Trucks #15
But what about the secondary controls on the truck body itself. Our bucket truck had a set. I cannot remember for sure but I though you could lower the boom without the truck running? But i am not sure about that.
   / Bucket Trucks #16
Most aieral lifts have apilot operated check valve. So truck has to be running for the levers on the ground to work.
   / Bucket Trucks #17
James,I think you are correct on the older model trucks you could hit the dead man switch and bring the bucket down manually.The newer buckets have a electric motor that needs the ignition key on to do this now.
   / Bucket Trucks #18
Back when I was working we had bucket rescue classes that did teach how to bring a bucket down on a non-running truck. 10+ years of time since I retired has blurred the memory of how it was done.
   / Bucket Trucks #19
The lift cylinders and outrigger cylinders are equipped with hydraulic blocking valves to prevent the cylinder from collapsing if system pressure is lost due to a broken line or pump failure etc. Therefore the boom cannot be lowered without system pressure or removing a few hyd. lines.
   / Bucket Trucks #20
Thanks guys for the info on the valves of the bucket trucks, it has been almost 15 years since I operated one, and it is getting a little fuzzy.
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A52472)
2012 TEX MEX...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
