Alternator wiring John Deere 3040
   / Alternator wiring John Deere 3040 #1
otto1234
longmont,co
jd3040
Howdy,
Got an old JD3040 and I have alternator problems.
The alternator has 2 leads: a thick red one -I bet this is alternator output
and a more narrow gauge wire leading in to the cables entering the cabin.
I bet this is the field voltage.
This terminal reads zero volts when tractor is running. and I have battery voltage (12.3V) on t he alternator output so its clearly not charging.
Does anyone have a wiring diagram that shows where the field wire goes in the cabin?
I have problems tracing its origin and its got to be broken/disconnected/or...
thanks
Otto
   / Alternator wiring John Deere 3040 #2
:welcome:
Welcome to the forum from Alabama. Sorry about your charging problem. How long have you noticed this problem?
   / Alternator wiring John Deere 3040 #3
Small wire should go to your alternator/battery light. If alternator light bulb is burnt out system will not charge.
   / Alternator wiring John Deere 3040 #4
Most likely Zebrafive is correct. DOes your alternatorbattery light work in instrument cluster?
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
