A little hydraulic cylinder
   / A little hydraulic cylinder #1
brain55
Brentwood, CA
This is me and a little hydraulic cylinder I reassembled today for a Tigercat. I say reassemble, because I didn't do the resealing, we don't have the tooling for the 4 1/2" piston nut.
Brian
   / A little hydraulic cylinder #2
Cool. I wonder if I could use that on my BX. lol
   / A little hydraulic cylinder #4
Impressive cylinder. What is the bore and stroke on that thing?
We have a rather large cylinder at work on an aluminum press. 14" diameter and 120" stroke with a 10" rod.
That press is powered by 3 150HP motors each driving a 80GPM pump. With a 2000 gallon reservoir.
   / A little hydraulic cylinder #5
Sure, but your little BX's "tank" is going to be pumped dry before that thing moves much.
   / A little hydraulic cylinder #8
My gatepost by my driveway are made using hyd cylinder rods. I cut one cylinder rod in half and the length after I cut them was around 10 foot. We had 2 lathes that had 40 foot long beds on them and would turn tie bars for the die cast machines we built. Many of the hyd cylinder we built and made parts for had any where from a 12 to 24 dia head on them and various lengths
   / A little hydraulic cylinder #9
I just got a couple little cylinders in the other day for my grapple project. They're the 3.5x8" with 2" rods SC has for $50.
I figure if I make the jaws right it can double as a wood splitter. :D
   / A little hydraulic cylinder #10
Someone was thinking when they set that lathe up by the door.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
2002 Bobcat 763 Compact Skid Steer (A56438)
2002 Bobcat 763...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
Rooster Weathervane (A59231)
Rooster...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
2017 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2017 CATERPILLAR...
