A little hydraulic cylinder
   / A little hydraulic cylinder #1
brain55
Brentwood, CA
This is me and a little hydraulic cylinder I reassembled today for a Tigercat. I say reassemble, because I didn't do the resealing, we don't have the tooling for the 4 1/2" piston nut.
Brian
   / A little hydraulic cylinder #2
Cool. I wonder if I could use that on my BX. lol
   / A little hydraulic cylinder #4
Impressive cylinder. What is the bore and stroke on that thing?
We have a rather large cylinder at work on an aluminum press. 14" diameter and 120" stroke with a 10" rod.
That press is powered by 3 150HP motors each driving a 80GPM pump. With a 2000 gallon reservoir.
   / A little hydraulic cylinder #5
Sure, but your little BX's "tank" is going to be pumped dry before that thing moves much.
   / A little hydraulic cylinder #8
My gatepost by my driveway are made using hyd cylinder rods. I cut one cylinder rod in half and the length after I cut them was around 10 foot. We had 2 lathes that had 40 foot long beds on them and would turn tie bars for the die cast machines we built. Many of the hyd cylinder we built and made parts for had any where from a 12 to 24 dia head on them and various lengths
   / A little hydraulic cylinder #9
I just got a couple little cylinders in the other day for my grapple project. They're the 3.5x8" with 2" rods SC has for $50.
I figure if I make the jaws right it can double as a wood splitter. :D
   / A little hydraulic cylinder #10
Someone was thinking when they set that lathe up by the door.
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
ATV (A59231)
ATV (A59231)
2008 Ford F-750 Fuel Service Truck, VIN # 3FRXW75S88V075566 (A57453)
2008 Ford F-750...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
Shop Smith (A57454)
Shop Smith (A57454)
Sukup 8R Subsoiler (A59814)
Sukup 8R Subsoiler...
