Kubota g1900 Cranks but wont turn over
   / Kubota g1900 Cranks but wont turn over #31
it looks like to me that the yellow wire should be plugged in to that white connector?
I think it was, that is his meter probe in it.
Its disonnected because i was testing the voltage when i took the pic. Why did you tell me to loosen that bolt? If its to see if fuel comes out, i did that to the middle one when i first got started and in fact fuel did come out.
   / Kubota g1900 Cranks but wont turn over #33
you say you did loosen the middle injector tube and fuel came out. was you cranking the motor? if not... the motor needs to be cranking and it should spit out under pressure. (small tiny spits of fuel, but consistently during cranking)
have you tried the starting fluid.. this will verify there is a fuel issue, or it will prove it is something else.
   / Kubota g1900 Cranks but wont turn over #34
Are you letting the glow plugs heat up for 20 to 30 seconds up before cranking the starter?
I will try your starting fluid and cranking thing this week. Its snowing right now and i dont get home til after dark.. Good tips though.
I normally dont have to but in this case yes, i have.
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2017 Claas Jaguar 860 Forage Harvester (A52748)
2017 Claas Jaguar...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
