Steering Cylinder on Kubota L245DT
   / Steering Cylinder on Kubota L245DT #1
rodsauder
ON
Mitsubishi Kubota
Hoping someone has some knowledge about older Kubotas. I have an bad leak on steering cylinder. Good people at dealership say nothing is available as tractor is so old. They say it is about 1970 ish origin. I can probably find seals etc to repair it but wonder if anyone knows of parts available for this model? I also would need a exhaust manifold. If anyone can help I would appreciate it. One last question ,does the rear end use the same fluid ( hyd ) as everything else.? I cannot find any level indicators or plugs etc anywhere on rearend. So, I am thinking that the fluid that goes in the top of the transmission feeds everything? Thanks.
   / Steering Cylinder on Kubota L245DT #2
I have a L245DT and if you go to tractor house .com you can learn the date of your machine. The steering cylinder did not come on all machines-it was a optional item. Most dealerships will try to get you to trade it for a new tractor. Mine is still running good after buying it used in 1982. Since nobody knew anything about the steering I took the cylinder to a local hyd. shop. They polished the cylinder and rod and repacked everything for 175.00. Put it back on and have used it with no leaks for a year. West Kentucky Tractor parts would be a place to try for your used manifold. Have you tried to have it welded locally? Trans /dralic fluid goes into the top of the trans and does the gears and everything. There is a drain plug on the left side of trans around the clutch pedal. Fill up to this point. The tractor has a hyd. screen on the left side of the case (setting in the seat drop your left hand it will be on the case about that far back).It will be behind a oval piece held on by 2 bolts. I had my tractor for 20 years before learning of this. Get a owners manual off E-bay or Amazon for less than 10.00. Do not use Messicks for the steering, I ended up with no useable parts after purchasing what they suggested.
Thanks, for all the info. I have already taken manifold to a local welder and will have steering cylinder rebuilt by a hyd shop. Thank You for your help. much appreciated.
FRONTIER FAV20 LOT NUMBER 68 (A53084)
FRONTIER FAV20 LOT...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2002 CHEVROLET C&K SERIES 7500 CAB & CHASSIS (INOPERABLE) (A52472)
2002 CHEVROLET C&K...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
