Another work/weld table
   / Another work/weld table
bigtiller, I had mentioned in my post that I did not have a removable support yet. Because you asked I decided it was time to fix that. Secondly we got 2 feet of snow today and I had time to work on it because I could do nothing else. The attached photo's show what I did. It is just a angled arm, flat stock .25" x 1.25", supporting the mounting plate for the vice. It does not get removed. It has like a half of a key hole to latch onto the stud. It only move out of the way to fold down the vice. I still loosen and tighten the 2 bolts on the mounting plate to use the vice and to move it out of the way. I used .50" hardware with nyloc nuts through out. The support leg/ bracket locks against a cut down .62" bolt. I did a OSHA and or a O-Sh$t test to confirm that it will work. I had to back off on the pipe because I thought I was going to break the vice off of the mount. Hope this answers you question. Later. 20150127_172134.jpg20150127_172216.jpg20150127_172312.jpg20150127_172606.jpg20150127_172349.jpgth[1].jpg
My mistake the support arm is .25" x 1.50"
   / Another work/weld table #13
Looks good! I need to build a welding table one of these days.
   / Another work/weld table #14
bigtiller, I had mentioned in my post that I did not have a removable support yet. Because you asked I decided it was time to fix that. Secondly we got 2 feet of snow today and I had time to work on it because I could do nothing else. The attached photo's show what I did. It is just a angled arm, flat stock .25" x 1.25", supporting the mounting plate for the vice. It does not get removed. It has like a half of a key hole to latch onto the stud. It only move out of the way to fold down the vice. I still loosen and tighten the 2 bolts on the mounting plate to use the vice and to move it out of the way. I used .50" hardware with nyloc nuts through out. The support leg/ bracket locks against a cut down .62" bolt. I did a OSHA and or a O-Sh$t test to confirm that it will work. I had to back off on the pipe because I thought I was going to break the vice off of the mount. Hope this answers you question. Later.<img src="http://www.tractorbynet.com/forums/files/build-yourself/408909-another-work-weld-table-20150127_172134-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/408910-another-work-weld-table-20150127_172216-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/408911-another-work-weld-table-20150127_172312-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/408912-another-work-weld-table-20150127_172606-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/408913-another-work-weld-table-20150127_172349-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/408914-another-work-weld-table-th-1-jpg"/>
Nice job on the vice mount, oldtimer! I went a different route for the vice on my table. I use it as a portable fixturing device for welding. It's free to slide wherever it's needed. image-3336547308.jpg Terry
   / Another work/weld table #15
That's pretty slick oldtimer, it looks like you had it all planned out.
   / Another work/weld table #16
Nice job on the vice mount, oldtimer! I went a different route for the vice on my table. I use it as a portable fixturing device for welding. It's free to slide wherever it's needed. View attachment 408947 Terry
Time to cannibalize that burnt out Mag-drill?
   / Another work/weld table #17
Baby Grand, that is definitely the IDEA of The DAY! .......gotta keep my eye out for one.
Terry
   / Another work/weld table #18
My dad always wanted a freestanding vise. He bought a nice new Wilton vise and I used a 10" section of an old "deuce and a half" M35A2 front bumper to mount it to. I welded that bumper piece on top of a 4" well pipe that was welded on top of a 3/4 ton brake rotor. Four 1/2" holes drilled in the rotor and mounted to his floor with concrete anchors made a really nice bombproof vise mount exactly how he wanted it. I'll probably do the same in my garage at some point. Sometimes you really need to wail on something in a vise.
   / Another work/weld table #19
I made this freestanding vice portable.
With a receiver for 'things'...and future things.
Terry
   / Another work/weld table #20
Looks like the weld table gave oldtimer cold feet?
I hadn't even noticed how the vice could fold out of the way.
That's a really thoughtful detail that will make the table much easier to use on oversized projects.
One more idea for me to crib - thanks!
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
Galvanized Livestock Gates (2x Gates) (A55218)
Galvanized...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2025 IR IRE20 Mini Excavator (A52377)
2025 IR IRE20 Mini...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
2004 TerraGator 8104 (A55301)
2004 TerraGator...
