Used Kubota RTV900 Diesel(?)
   / Used Kubota RTV900 Diesel(?)
Here's the one I'm looking at, 440 hrs, he'll take $6k:
- djb
Pretty wheels, been washed, should work!
lol
In general cosmetic blemishes don't bother me, nor does 'polish & shine' impress me. But sometimes [I think] there are indications that a vehicle has been worked hard or handled gently. The one I looked at last night was a work horse; I saw it in action. The other (orange) one, from talking with the guy on the phone, I don't believe it's seen much mud for the four years he's owned it. Sounds like it's been an urban mantenance vehicle...but granted, I don't know that for sure.
I plan to look at the orange one tomorrow, and if it passes muster, it's coming home with me.
- djb
   / Used Kubota RTV900 Diesel(?) #25
when inspecting, check oil levels, engine and hydraulic, and look at outer air filter...you will discover if owner knows where these are and how to do... and it's more realistic than just "kicking the tires"
'Good luck!
   / Used Kubota RTV900 Diesel(?) #26
I wondered how much I'd use a hydraulic dump anyway?
Most utility vehicle owners find their beds fill with tools pretty quickly and that transport loads are pulled in a trailer.
If you are going to move heavy loads you want the load low for stability, not high in the bed.
MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler - Welcome
HD 1500 TA - Trailers - Polar Trailer
You can special order a Polar trailer from Home Depot.
The MUTS trailers are the class act in all-terrain trailers. The mast & winch dump feature is worth a lot.
   / Used Kubota RTV900 Diesel(?) #27
agreed, it depends on your use and other equipment available. I have never used the hydraulic dump feature. It is handy to lift the bed to get at the engine, occasionally. I do have a manual dump trailer which holds no more than 3 FEL buckets of material. I've used that a couple of times for transporting material a long way, leaving the tractor at the material pile. The rest of the time, the trailer holds all my fencing supplies and tools
   / Used Kubota RTV900 Diesel(?) #28
The only issue with the hydaulic dump bed, is if you have a trailer hitch attached, and back into stuff, and dump, well I have crushed three tailgates. LOL.
I did one, some other people did the other two.
There is a post on TBN about this unfortunate event. I ended up taking the bed off, just to rebend the bottom. LOL.
It has a slight curve, now, currently, from the last crushing move.
Hydraulics are un-forgiving. :) But if you can swing it, I'd go with them!
   / Used Kubota RTV900 Diesel(?) #29
So, Rip, does your hydraulic lever now sport a custom made warning message to remove the trailer hitch??:yes:
   / Used Kubota RTV900 Diesel(?) #30
That is not a bad idea! Them trailer bed parts are expensive. And the decals are separate costs. :(
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2023 UNVERFERTH 632 LOT IDENTIFIER 146 (A53084)
2023 UNVERFERTH...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A51247)
UNUSED CFG...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
