300 pounds of play sand later
   / 300 pounds of play sand later #1
square1
Michigan
Ford 1700 4x4 w/ FEL
I'm back on high ground :) Ice under snow on hills presents quite the challenge sometimes!
   / 300 pounds of play sand later #3
CHAINS=GO
   / 300 pounds of play sand later #4
It's one thing to chain up your tractor, quite another ti chain up your passenger vehicles. Then there are visitors and first responders.
   / 300 pounds of play sand later #5
Sand is nice, but it is heavy. (or didn't you notice ;)? ) It also is still there in the spring and it builds up over the years. I found that fire place ash works better. I've sprinkled a bucket of ash lightly on slick ice and went from near impossible to stand on to easy to walk on with no feeling of impending doom. Plus, the as washes off in the spring with melt or rain AND it is a good source of nutrients for the lawn and increases pH. (it's like lime)
But if you don't have a fire place, you may not have much available.
   / 300 pounds of play sand later #6
Ice sprinkled over with ashes works great. When the sun is out, the darker color helps the ice to melt sooner, getting down to the gravel. Only drawback I've seen is the need to be careful not to track it inside. I only use ashes 1-2x per winter on the drive when it is shear ice and I can't walk to the car, and the car spins its wheels trying to move.
   / 300 pounds of play sand later #7
Ash works pretty nice in some situations. My tip is to put it in an onion bag (the fine mesh variety) the ash is sticky enough it doesn't just flow out, but dispenses nicely when you shake the bag.
   / 300 pounds of play sand later #8
Salt mixed with the sand also helps when the odd sleet, ice, etc, at higher sub-freezing temps.
Sand is nice, but it is heavy. (or didn't you notice ? )
That's why I stopped at 300 pounds ;)
   / 300 pounds of play sand later #10
My woodstove ash is like a fine powder - a puff of air will catch it. I use the ash bucket and a tin can to scoop and shake it out over ice.
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
KOMATSU HM400-3...
2012 Dixie Chopper Magnum 2460 60in Zero Turn Commercial Mower (A59228)
2012 Dixie Chopper...
