ID this tree
   / ID this tree #1
sensabmc
Member
Vancleave, MS
Mahindra Max28XL
I think it's a cypress. I live in the gulf coast region of Mississippi.
The logs weigh a ton. I can pick up the 4 and 5 foot long sections with my loader but the 10 foot section won't even move.
20-24" in diameter.
Here are the pics. I cut a sample block so you can see the inside. The inside is what has me stumped.
   / ID this tree #2
Looks like cypress. Was it under water?
If it's cypress it will smell great.
   / ID this tree
Came from about 30 feet where it lays so no water. It smells like gasoline to me.
   / ID this tree #4
Hard to tell. Not much bark left on the trunk. Is the wood spongy? If the tree has been dead for a long time, it could be a fungus inside the wood.
   / ID this tree #5
Looks like the wood is either spalted, or has begun to decompose. Spalting is the early stage of decomposition that gives the wood interesting patterns, but the wood is still usable. Once it gets past that point, it's not much good.
When dried and cured, Cypress looks very much like other white softwoods. When fresh cut, it will have a slightly darker appearance.
Here's a milled cypress beam, but this was standing dead wood so it was basically dried/cured in place:
Here's a piece of spalted beech for conversational purposes:
   / ID this tree #6
I have seen at least one upscale home in this area trimmed on the outside with something he called "Pecky Cypress". It had a lot of holes and grooves, supposedly caused by fungus. Could this be what we have here? Cypress is not common around here.
   / ID this tree #7
Well, I know its not any kind of tree from around this neck of the woods.
Dump bed (A51692)
Dump bed (A51692)
1999 FORD F-450 SUPER DUTY SERVICE TRUCK (A54756)
1999 FORD F-450...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
Frontier WR1008 - 8 Wheel Pull Type Hay Rake (A55218)
Frontier WR1008 -...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
