Flux-core wire-feed welding different thicknesses of metal
   / Flux-core wire-feed welding different thicknesses of metal #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
So I plan to practice this tomorrow, but thought I should get some input from folks here.
I have to weld a short 2" piece of 1/8" wall rectangular tube to some 1/4" plate. End of the tube will get welded to the flat of the plate by reaching through the inside of the tube to where it butts against the plate, and place a couple short welds inside where the pieces meet. Strength isn't real critical for this. The welds will basically be wide tacks.
Not sure whether I should set the voltage and wire rate for 1/8" material and know I will have lesser penetration on the 1/4" material, or set for 1/4" material and direct the wire into the 1/4" material then push the puddle up onto the 1/8" tube. Be curious to know what others would do.
thanks,
219
   / Flux-core wire-feed welding different thicknesses of metal #2
I just had to do this for a member over on Welding Web. I took one of my engine drives, and LN-25 wire feeder with .045" NR-212 wire to his house. I had to weld a 1/4" angle iron to .065" galvanized square tube. Flat, vertical, and over head. What I always do is use a J pattern. Keep the long side of the J on the thicker material, and just bounce the curl of the J onto the thin material.;)
Excellent, thanks Shield Arc!
1521 (A57192)
1521 (A57192)
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2025 JMR Tree Boom Skid Steer Attachment (A55851)
2025 JMR Tree Boom...
1642 (A57192)
1642 (A57192)
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
CATERPILLAR 259D3 SKID STEER (A52707)
CATERPILLAR 259D3...
