Use of chains on concrete floors ??
   / Use of chains on concrete floors ?? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Been thinking about installing chains on my Kioti tractor.Question for you folks with chains installed how are they on concrete floors?Do they scuff them up?My 3 barns have concrete floors.Thanks for any info.
   / Use of chains on concrete floors ?? #2
I have had no signs of any kind of damage.
   / Use of chains on concrete floors ?? #3
When I used to have a dairy farm before becoming disabled, we ran chains on the tractor we cleaned the barns with and the tractor pulled the feed wagon with. Never noticed any damage to the floors, scraping the floors with the loader wore the floor more than the chains did. The chains wore faster on concrete than on dirt, however, the extra traction on floors with frozen manure on them out weighed the wear.
   / Use of chains on concrete floors ?? #4
I have chains on all 4 and park it in my garage. I've been using chains on my tractors for last 12 years and don't show any sign of damage to floor. I suppose if one would spin the tires or lock them up pulling in it might cause some scuffing or scraping to concrete. I have 4 link ladder on rear and V bars on front.
That being said I must say my garage floor is not finely polished nor painted. When poured I told the mason I did not want it smooth as glass but smooth enough to easily sweep. If yours is very smooth or painted I could see where chains would mark them up. If you are concerned you could buy some rubber stall mats from TSC or some cheap particle board and put them down to park on. Here's a couple pics of my floor.
   / Use of chains on concrete floors ?? #5
I use 2 link ladder chains on the rear of my tractor and haven't had any issues. I thought I might have to put some type of rubber down but never needed it.
Sent from my iPhone using TractorByNet
   / Use of chains on concrete floors ?? #6
I use 24x36 rubber mud flaps to drive on in the winter in the garage. Helps to protect the concrete from the sharp v-bars, catch mud & melted snow. Also put one under the loader bucket ot keep it from freezing to the floor
   / Use of chains on concrete floors ?? #7
The amount of damage to the cement floor depends on the type of chains and the weight of the tractor. Aggressive ice studded chains with loaded tires on a mid size compact tractor will start to chew up the concrete surface, I found out. I put down scraps of sheathing to drive on. Anything to keep the studs off the concrete.
   / Use of chains on concrete floors ?? #8
Whats going on George....I don't see any oil leaks from your tractor, that can't be a Kubota.:p
   / Use of chains on concrete floors ?? #9
I owned a Kubota once but they don't make them in Blue. Over the years I've had blue, gray, green, orange, red, and now back to blue. No leaks yet other than a hyd. line which I fixed, knock on wood.
   / Use of chains on concrete floors ?? #10
Good Morning Coobie,
I have chains on my 49 Super A Farmall, they have the ice cleats and they do pock mark the concrete floor. That tractor is only about 2500 lbs, although I do have about 400 additional lbs on the drawbar. I would suggest some plywood sheathing or rubber mats as someone else suggested, if your worried about marking up your floor !
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
