self powered attachemnts, mowers, snowblowers, etc, coverting a PTO driven unit
   / self powered attachemnts, mowers, snowblowers, etc, coverting a PTO driven unit #1
clayhardock
Member
Cochrane Alberta
JD 2720 & 2305 & F932
I have been thinking about building my own offset tow behind mower. I have a swisher now but its getting beat to death in the fields I do. I'm thinking of taking a 3pt 60" finish mower and mounting a 15-20hp motor on it to power it and then rig up a tow system.
Some thought are:
How to drive and gear the system. Most small engines are governed at 3600rpm. I'm guessing peak power to be around 3000rpm, would need to gear that down to 540rpm. Chain or belt.
Tow system. The "trailer" type system with a pivot at the back of the tractor is what my Swisher uses. While its a simple system it drives me nuts whenever I turn a corner as it custs the corner in a tighter arc than the tractor leaving an uncut swath of grass. Having an arm mounted solidly off the back of the tractor would make it travel more in line with the tractor(like a 3pt implement) however no pivots need to betaken into account for forward and back and side to side.
Motor, vertical or horizontal shaft? Horizontal shaft would be easier to drive the input on a PTO. Vertical shaft motors are cheap to buy as there are tons of 15-20hp dead or cheap garden tractors with good motors in them that can be bought used for cheap. How could I turn the drive(and maybe gear it down) to drive a PTO input gear box?
Front or back? Since I'm fabbing anyway wouldn't it be better to mount it off the front where I can see it?
Anyone converted a PTO driven unit to self powered? If it goes well maybe I could mount a motor on a 3pt snowblower and use it on the front of my tractor.
   / self powered attachemnts, mowers, snowblowers, etc, coverting a PTO driven unit #2
If one used a vertical shaft engine, one may be able to change the pulley under where the current gear box sets and get the correct ratio, if not a jack shaft could be used as well, or a gear box off a pto generator could be a possibility,
if you want front and have loader consider mounting to the loader, the other option could be a belly mount, they use a front mounted loader mower on skid steer a lot,
they make mowers that are for ATV, that have there own engine, https://www.google.com/search?newwi......1c.1.61.img..5.4.2185.uDlt24nMBPk#imgdii=_
another option is to make a "pony or "fore cart" that the engine and gear reduction sets on and may even have hitch to accept the three point, mount off the mower, and that become the front of the mower and your hitch and balancing wheels are on the pulled "pony/fore cart" some thing like this, contact
   / self powered attachemnts, mowers, snowblowers, etc, coverting a PTO driven unit #3
Some thought are:
For power, consider hydraulic. Depending on your tractors hydraulic specs, you would likely need a PTO hydraulic pump and reservoir. There have been several conversions posted here on TBN.
Front is best for me and the 7' brush hog.
Bobcat has a front mount finish mower, so you know it works.
Mower Attachment - Bobcat Company
And one for a UTV.
Mower Attachment for Utility Vehicles (UTV) - Bobcat Company
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2012 Ford F-550 4x4 Chipper Truck (A52377)
2012 Ford F-550...
2008 Ford F-250 Reading Service Truck (A55788)
2008 Ford F-250...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A55788)
2014 Ford F-550...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
