Starting problem on my international 574
   / Starting problem on my international 574 #1
OlaussJP
Norway
International 574
I have starting Issues on my 574 model 1972, have a new battery, missing service manual, the starter won't kick in, only a click when I try to start it.
Anyone hve some good ideas what I might face ;-)
   / Starting problem on my international 574 #2
Always make sure your tractor is in "NEUTRAL" when playing around a starter.
See if you have 12 volts at the starter, it could be the solenoid on the starter or the starter itself.
It could also be ignition switch related or poor connections to the starter.
There are ways to "bypass" the solenoid on the starter, I prefer not to show or tell you how for safety reasons.
You could also remove the starter and test it or have it tested.
Good luck.
Good luck.
Hi
Thanks for the tip, I will try them out
BR
JanP
   / Starting problem on my international 574 #4
Check your ground cable where it attaches to the chassis, and make sure it is a good clean, tight connection.
   / Starting problem on my international 574 #5
Probably a bad cable connection as mentioned.
Here is a good troubleshooting procedure: http://www.youtube.com/watch?v=XhRPLgH6uZg
   / Starting problem on my international 574 #6
:welcome:
To the forum from faraway from Norway.
PALLET OF MISC PAINT (A51244)
PALLET OF MISC...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2014 Nissan Frontier Pickup Truck (A50323)
2014 Nissan...
NEW Woods Reverse Rotation 5ft Tiller (A52128)
NEW Woods Reverse...
