Not talking about wet wood, but it will vary based on the treatment type and species type. I have some marine lumber, treated pine, that is exceptionally heavy, to the point where you'd think the wood is wet!
SYP ranges from 25-37 lb/cu.ft when dry. Different forms of treatment can add anywhere from 3 lb/cu.ft to as much as 5. Oak is around 45 lb/cu.ft. If dealing with treated pine that could be in the 28-42 lb/cu.ft range, to me that's not a whole lot lighter than oak at 45 lb/cu.ft.
Right after treatment, pressure treated SYP is around 55 lb/cu.ft, not far off from straight water at 62.4 lb/cu.ft. One reason I hate dealing with large wet PT wood -- something like a 2x12 16 footer is a friggin bear when wet.
Back to the trailer -- I transport my
L3200 on my 7x16 landscape trailer (7K gross with 5400# payload available) and it's no problem at all. However the standard mesh rear gate -- even with supports spaced at 12" -- does not look strong enough to me, so I do not use it with the L -- not even willing to give it a try. The gate was fine for my previous
B2920 though -- I probably trailered that hundreds of times and the gate did fine. At some point I plan to buy or make proper ramps to support the
L3200. Right now I just back the trailer up to a high spot on my land and creep on/off in 4WD. When I picked up the
L3200 at my dealer, we backed the trailer down into a low spot that they dug just for loading/unloading.
