Last summer I borrowed some forks, and I tried to move a pallet of concrete with the CK20 and it was not strong enough to handle the load. I think there were about 600 pounds on it. Thinking back, I didn't try to troubleshoot it, and I may have been in high instead of low but I don't know if that could be part of the reason?
I checked the specks on Kioti.com and it says my tractor can lift over 1000 lbs. Am I reading this wrong?
Thanks!
My CT235 would have trouble with 600 lbs on a pallet. You do not have enough loader for what you want to do.
Your CT235 is rated for 740 lb. pallet load using SSQA mounted forks and 800 lb. on 3 pt. I lift 1050 lb. pallet of feed once a month out of back of my truck and can lift 5' high with 800 lb.. rear ballast. Could probably lift higher but no need and I chicken out.
We have the identical loader. How are you lifting that weight...
