Fuel Barrel question
   / Fuel Barrel question #1
pizzaguy
Northwest IA
Kubota L3240 HSTC
I have posted earlier that I am going to get an old fuel barrel filled again after not using it for several years. I have cleaned it out, new filter and checked for leaks. I now have about 5 gallons of gas in there and delivery truck will not be here until sometime next week. I bought a large jug of StaBil Marine stabilizer to keep fuel fresh. Is there any problem in adding the entire jug of StaBil to the 5 gallons in the tank so when truck gets here it will all mix up? I will not be using anything out of the barrel until well after it is filled up, but don't know if adding it early will decrease the potency so it will not work as well. Gas barrel is on an overhead stand so adding later and mixing is not as easy as with a 55 gallon drum. Any advice is appreciated.
   / Fuel Barrel question #2
No problem at all. The boats I maintain hold anywhere from 85 gallons to 300. When we store them for the winter we do just what you are doing, add the stabilizer then top off.
Chris
CAT Skid Steer (A50322)
CAT Skid Steer...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2012 Ford F-550 4x4 Chipper Truck (A52377)
2012 Ford F-550...
