HELP before snow starts again
   / HELP before snow starts again #1
matoyan
Rhode Island
kubota b1750, b7100 hst, b2150 hst
I have a JD 750 and the screw for the rod kit (basically a tie rod end) sheered off yesterday while doing some maintenance on the tractor. My local dealer is closed today and closed at 12 yesterday (go figure). Does anyone know the compatible part number so that I can walk into NAPA or AutoZone and get a part that fits on a car or truck but also fits on the tractor? The JD book says that the part number(s) is AM878080, CH14551, AM875953, TR-8290, or CJD4001. We have another 18 inches of snow on the way and the plow is on the tractor. The rod kit fits at the end of the power steering cylinder. HELP!!!!!
   / HELP before snow starts again #2
Take all those part numbers and the broken part to the parts place. They should be able to look it up and match the broken part.
tried that but didn't work.
   / HELP before snow starts again #4
Weld it"
Sent from my iPad using TractorByNet
   / HELP before snow starts again #5
Your in luck, I think they'll be open today.:)
   / HELP before snow starts again #6
Did it break off flush with the PS cylinder's threaded rod? If so, you may have to drill out the rod end and temporarily screw it back onto the remaining threads of the PS cylinder rod. It may not work because of the length lost by the section that broke off, but it might get you hobbling along through the storm. Sounds to me that you need a new PS cylinder in addition to a rod end?
What do you think made the end break off? Did you hit something with it?
2019 KOMATSU PC210LC-11 EXCAVATOR (A60429)
2019 KOMATSU...
2017 Versatille 260 (A60462)
2017 Versatille...
2018 Peterbilt 348 T/A Rollback Truck (A59230)
2018 Peterbilt 348...
Harper TV130 High Dump Turf Vacuum Sweeper (A59228)
Harper TV130 High...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
