Cutting Grade - CUT, BB and FEL Do the Job?
   / Cutting Grade - CUT, BB and FEL Do the Job? #1
Beltzington
Appling, Georgia
JD 3720
I want to grade a 20' by 40' slope to reach level for a shipping container, to do this I need to remove a good bit of clay under grass as the top of slope is about 18" higher than the lower. I have a 4,000lbs, 36hp CUTS, an FEL and a heavy 6' Box-blade with rippers. I have never used the BB and after watching many how-to videos it appears they are primarily designed for leveling not digging.
Hire this out or give it a go?
   / Cutting Grade - CUT, BB and FEL Do the Job? #2
Although I've never done such a chore, it sounds doable to me. As I understand it the rippers will break up the dirt and the BB + the FEL can move the dirt to the place of your choice. Probably you can get 'er done in a couple days. The wetness of the dirt can affect the chore, I'd think.
   / Cutting Grade - CUT, BB and FEL Do the Job? #3
Give it a go. Box Blade or an Rear/Angle Blade are the two primary choices for your task.
Box Blades will move a lot of dirt, one load at a time. Keeping playing with the Top Link adjustment until you get the 'bite' you want.
You might consider a Tooth Bar for your bucket, to pair with the Box Blade. The Piranha Tooth Bar gets great reviews here.
Best to rip across, down, or up the slope? I would want to minimize disturbing the soil at the bottom of the slope?
   / Cutting Grade - CUT, BB and FEL Do the Job? #5
Whatever works. You may (or may not) find that clay "peels" best without the rippers.
Soil moisture makes a big difference.
Do not get frustrated. A Box Blade looks like it should be mastered in fifteen minutes but it takes much longer.
You can spread "spoil" thinly be raising the BB just a little, until the spoil flows out slowly, while moving forward.
   / Cutting Grade - CUT, BB and FEL Do the Job? #6
I'd travel across the slope. Lower the uphill side of the box blade so it digs in. That's not a very large area, shouldn't take long unless you hit big rocks.
   / Cutting Grade - CUT, BB and FEL Do the Job? #7
With the top link set right so that the rear cutter bites, you can easily shave off layers of soil with a box blade. Start with small bites to get a feel.
   / Cutting Grade - CUT, BB and FEL Do the Job? #8
+1 on what bigdeano said. And if you wanted to add a tooth bar, +1 on what jeff9633 said. I dug an entire pond with my FEL with tooth bar. Very similar tractor size. It's roughly 80X80 semi-circular and at deepest point about 8' deep. Used the box blade very little on that project except for ballast weight to max my loader abilities. I have hard red clay here like you do, but tooth bar helps you dig right through it for a full bucket every time. Box blade rippers will cut right into it too if your box blade has a good bit of weight to it.
No tooth bar needed though. You can use your box blade and it's rippers and turn up layers, then move the dirt with FEL or drag down hill with box blade. Only thing about BB is you need to change angle and bite frequently depending on your approach for the project, and without top and tilt, it's time consuming to make the manual adjustments. Still very very doable with your machine. In fact, I'd consider this chore to be light-work for your machine.
tractorshopper;4036709 I dug an entire pond with my FEL with tooth bar. Very similar tractor size. It's roughly 80X80 semi-circular and at deepest point about 8' deep. Used the box blade very little on that project except for ballast weight to max my loader abilities. I have hard red clay here like you do said:
I can't dispute your accomplishments and don't intend to but I have tried to "dig" a few times with my FEL and have always had the gut feeling it would be very easy to bend the arms on the FEL because of how they are mounted so far back from the bucket. Years ago I did quite a bit of heavy digging with a skid-steer and never got that same feeling, it was a beast. Any thoughts on my assumptions?
   / Cutting Grade - CUT, BB and FEL Do the Job? #10
When I leveled a pad for a camper, I used the rippers on the box blade to rough up the area and my FEL can pick up the lose dirt to dump it on the down hill side. I also tilted my box blade so the uphill side digs in more and the extra dirt spills out on the downhill side. It's a good learning experience, go for it...
2007 Volvo VNL Tri-Axle Dump Truck (A56858)
2007 Volvo VNL...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2015 Ford F-750 Stellar 10628 10,000lb. 5 Ton Mechanics Crane Truck (A56858)
2015 Ford F-750...
set of 4 tractor trailer tires Roadforce (A56436)
set of 4 tractor...
