Lifting capacity
   / Lifting capacity #1
txturbo
Member
Rosenberg,TX
Ferguson TO35, JD317
What is the lifting capacity of the TO35 lift arms?
   / Lifting capacity #2
I dont think they rated them back then.
What loader is on it? How big are the cylinders?
   / Lifting capacity
No loader....I'm talking about the rear lift arms.
   / Lifting capacity #4
That makes sense.
Not sure. I know the 8n which is similar is only rated @ 800#. I think the ferguson is similar but ran a higher pressure. So prolly around 1000-1200.
IS there something specific you are wanting to lift?
   / Lifting capacity
I move a lot of motors around and I want to get a gin pole. Just wanted to make sure I would be able to pick them up.
   / Lifting capacity #6
Your average motor shouldnt be a problem.
May have issues if you start working on big diesels though
   / Lifting capacity #7
It will probably make a difference how far out away from the hitch you are planning on lifting; leverage, ya know.
I am currently welding together a boom/pole so I have been considering the same issues.
   / Lifting capacity #8
been around to35 all of my life. Depends on how far out you are lifting. Should lift any motor but like the other poster said, you get to lifting diesel motors out of semis would need some counterbalance weight on the front.:)
   / Lifting capacity
nothing like that....I just need to pick up Cadillac V8s off the floor and put on a trailer.
   / Lifting capacity
Picks up Cadillac and hemi V8s with no problem. I moved about 6 motors this weekend. Tractor ran great except for that new ignition switch I put in it. Had to cut my new wires so I could keep working. Something burned out inside. First sign of trouble was it wouldn't shut off with the key. Had to disconnect power to the coil. Then when I tried to restart it it would start then die when I let go of the key. So I guess the contact for the ignition terminal burnt out.
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51691)
2013 International...
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A51692)
2017 Freightliner...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2015 Forest River Rockwood Roo 19 25FT T/A Travel Trailer (A51694)
2015 Forest River...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
