Does anybody make a 3pt hitch salt/sand spreader?
   / Does anybody make a 3pt hitch salt/sand spreader? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
Does anybody make a 3pt hitch salt/sand spreader w/ PTO drive? I need one to hang on my BX2200 (little thing needs to do SOMETHING during the winter), and I'll build it if I have to, but I'd rather just buy one (if it isn't too obscene). I've seen them hanging off the back of pickup trucks (like the Fisher 500/1000/2500), which I assume use a 12V motor to run the flinger. Anyway, this sounds like something that should exist - I just can't seem to find one.
   / Does anybody make a 3pt hitch salt/sand spreader? #4
hello I built a hydraulic one and man it works awesome but the dryer the sand is the better it works
Thanks - it looks like the Herd stuff is the beefy and expensive option. I also found seed/salt spreaders that were in the 500-700 range that might do the job. Given that this is a once or twice a year use implement, I think at close to 2 grand for the 'good' ones, I'd be tempted to build one. 500-700 is a different story. I'd like to see the mechanisms inside to see what the differences are.
   / Does anybody make a 3pt hitch salt/sand spreader? #8
If you want a 3pt model for free flowing salt/sand that will work on a small tractor like the BX, our Agrex XA150 spreader will fit perfectly and the salt/sand kit is available as an option.
For larger tractors, models with higher capacities are available.
Free shipping to a staffed commercial business or supporting freight terminal within 1,000 miles of Newton, NC.
For you, there are terminals in Bedford and Belmont.
Travis
Travis
Thanks! I'll keep your place in mind - probably exactly what I need. What's the difference between the 150 and bigger units? Their listed capacities are quite different, but they look the same in the pictures and prices aren't all that different. Would I be better served paying a few more bucks and getting a bigger spreader? I do have an 1100ft drive, so there is an advantage to a big hopper...
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET TRUCK (A51406)
2012 FREIGHTLINER...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2008 CPS END DUMP (A53843)
2008 CPS END DUMP...
